Random start problem (extended cranking)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bleeds, Dec 14, 2021.
  1. Dec 14, 2021 at 10:07 AM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    I have a 2005 Tacoma 4.0L, 240K miles. The truck runs well, mpg seem normal, no codes. The problem is it will randomly crank about 10+ times before starting. 9 times out of 10 it'll crank 3-4 times and start which has been its normal. I can't figure out for the life of me why that one time it sits and cranks but it always starts.
    New parts with the last 5-8 months:
    Battery
    Fuel pump
    MAF
    O2 sensors(denso)
    Plugs
    I'm leaning towards plugged or leaking injectors but I have none of the other symptoms of such. Maybe the Fuel Pressure Regulator? Again, no other symptoms of a bad one. I've read other threads pointing at a coolant temp sensor. It, too, seems to operate normally.
  2. Dec 14, 2021 at 10:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I would want to put a fuel pressure gauge on it and check and make sure fuel pressure holds when the engine is off.
    Pressure should not drop below 21 psi for at least 5 minutes after the engine is turned off, if it does you have a bad check valve in the fuel pump, a leaking fuel pressure regulator, or a leaking injector.
    TnShooter likes this.
  3. Dec 14, 2021 at 10:55 AM
    Bleeds
    Bleeds [OP] Member
    2005 Taco 4.0
    Looks like I have my work cut out for me. Thanks
  4. Dec 14, 2021 at 10:58 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    my '07 has about the same mileage and does the same, and has for some time. Very random. When I crank, if my truck doesn't fire right away like it usually does, I don't keep cranking. Instead, I shut off the key and start over and it has always fired quickly, as normal, on the second try. So, I haven't done anything to fix it, for now.
