Random Suspension Idea
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, Apr 27, 2011.
  1. Apr 27, 2011 at 12:26 AM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Alright this randomly popped into my head. People run 5100's with Eibach coils. And OME coils with Nitrochargers or 5100's. Has anyone ran Eibach coils with Nitrochargers? I've read 5100's stiffin after awhile, would there be any benefit to run eibach's with nitrochargers. Or is that a retarded idea because the nitrochargers are valved for OME coils? If it's a dumb question then just let this thread slowly disappear, if not then feel free to chime in on opinions lol. Oh and sry if this has previously been discussed.
  2. Apr 27, 2011 at 3:11 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    I dont think anyone is running Eibachs on Nitrochargers. The Nitrochargers are specifically valved for the OME's and probably wont ride well on the Eibachs. But Idk for sure.
  3. Apr 27, 2011 at 6:27 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    think i have the nitros now. came with my truck, they are leakin now haha
  4. Apr 27, 2011 at 1:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I've always wondered whether that whole "nitros are designed for OME coils" thing isn't more marketing hype than anything else.
    The spring rate on eibachs (620/650#) is definately higher than any of the OME coils, from what I've heard. I suppose it is possible that the valving in the nitros might not work well with stiffer coils or maybe the spring perch might be too weak to handle ~600# coils.
    It is an interesting idea though. You should try it, just to see how it works out.
  5. Apr 27, 2011 at 3:36 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    someone needs to be the guinea pig lol
  6. Apr 27, 2011 at 5:03 PM
    lonzorizo
    Lonnie
    Hoopa, Ca
    That was my thoughts also, that the OME Nitrochargers are valved for much less spring rate. But on the same note, aren't the 5100's valved for stock coils?
  7. Apr 27, 2011 at 5:59 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Yeah, this is interesting, because the 5100s are designed for the stock progressive coils, right? Which are like 375 lb coils. OMEs are 500 lb linear, not progressive. I've never seen nitrocharger perches up close, but the 5100 perch/clip doesn't look extraordinarily robust. I would think the the valving and spring rating being as close as possible to each other would make the most sense for a better ride.
  8. Apr 27, 2011 at 8:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Here is the best pic I've seen. This was posted by one of the toytec reps in another thread. RCD 5100 and OME Nitrocharger. Perch looks pretty sturdy to me.
    Scott, I think you need to try this. :D After all, you've been rather vocal about your 5100s not being as good as they originally were. :eek:
  9. Apr 27, 2011 at 8:48 PM
    747 function > form
    1st Gen.
    I agree with Digirat...and if you do too, you should leave him positive r*p. OP, good luck man.:)
  10. Apr 27, 2011 at 9:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :eek:
  11. Apr 27, 2011 at 11:11 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Great pic! Interesting. Look at the difference in perch height! That looks like 1.5 inches?
    Have I been that vocal? I didn't think I'd been that vocal...
    I am about to pull the trigger on nitrochargers for my 881s, and also some LR UCAs to fix the caster. Driving me nuts. I am waiting to see if I win the DSM coilover giveaway, and If I do, I'll sell 'em for the price of nitros and LR UCAs...:spy:
    Who wants to buy some slightly used 5100s?
