Random Tacoma & Audio stuff in Los Angeles. Alternator, belts, clock, double din, terminals, cables
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Caligula, Jan 4, 2016.
  1. Jan 4, 2016 at 7:32 PM
    Caligula
    Caligula [OP] Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Here's some random stuff in my storage box that I don't need. Much of this stuff is "make an offer before it goes in the trash". Ill consider any offers as long as they are not insulting.
    Located in Koreatown.
    DECALS!!!
    Pyle PLRDD19UB double din stereo. Looks and functions well, was just looking for something more fancy. I can include some electrical connectors to match the ones ive used on the harness: $40
    Stock speakers, not pretty but they work: Make offer.
    Used belts, no cracks: make offer
    Used hoses: make offer
    Used Denso alternator, dated 2011. I replaced mine thinking this one was bad, but it turns out it was a bad connection to the fuse box. I'll guarantee the part for 60 days and install it for a fee (or alcohol). $50.
    About 4x4 feet of super thick vinyl sheeting. Used to make replacement vapor/sound barriers for door panels: $5
    Door panel parts, passenger side: $15
    Glove box, good condition: $25 (for 01-04 grey interior, it did not match my 00 grey interior)
    Clock (has not been tested, but we can test function on your truck, or ill give you a 7 day warranty): $25
    Cock delete pannel: $15
    This trim panel, kinda broken: make offer
    Door panel clips, fender flare clips: $0.50 each
    Assorted Toyota and BMW relays: make offer
    Used headlight bulbs: $10
    Assorted electrolytic capacitors:
    All kinds of tin coated, copper core, spade, fork and ring terminals. Spade terminals are in 2.8, 4.8, and 6.3mm and include plastic insulator sleeves. Let me know what you need and i can put together a package: Make offer
    Pioneer DEH-P4300 single DIN. Includes direct mounting bracket, storage cubby, and harness for 1st gen. taco: $60
    Some kind of quick change oil change plug and drain kit. Dont think it worth with Toyota threaded pans: $5
    A crap load of wire
    Most is CCA, including 4, 8, 14, 16 gauge: make offer
    Pure copper 4 gauge and 14 gauge: make offer
    2 channel RCA cables: $5-10 each
    make offer
    New LED bulbs for instrument cluster, A/C panel, gear selector: make offer
  2. Jan 4, 2016 at 7:44 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Interested in the leds...do you have blue 94's or any white ones? Also any white or blue 74's? Are you willing to ship up to big bear lake, 92315?
  3. Jan 4, 2016 at 8:02 PM
    Caligula
    Los Angeles, CA
    The 74 bulbs, yes and yes. I have the ones with the plastic housing, you can see them clearly in the small plastic bags. I also have a few of the ones that are 'board mounted' ones like this.
    Which ones are the 94 bulbs for?
  4. Jan 4, 2016 at 8:04 PM
    uneaqs
    uneaqs New Member
    don't suppose you have any of the little plastic retainer rivets that hold that trim panel under the stereo in place do you? can't seem to find any online with reasonable shipping fees.
  5. Jan 4, 2016 at 8:04 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I want that four gauge wire.
    What lengths do you have?
  6. Jan 4, 2016 at 8:05 PM
    ramonortiz55
    Ramon
    Texas
    stock
    lol this guy signs up just to make a purchase :D
    uneaqs[QUOTED] likes this.
  7. Jan 4, 2016 at 8:06 PM
    Caligula
    Los Angeles, CA
    I have a parts wholesaler i get all my OEM parts from, and he even had to special order them. I may have one or two around here. If you want them new, i can order them and send them to you.
  8. Jan 4, 2016 at 8:07 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I am also interested in the green box full of panel clips.
    The little Tupperware container with the ring terminals and the little box of yellow ring terminals below it.
  9. Jan 4, 2016 at 8:08 PM
    Caligula
    Los Angeles, CA
  10. Jan 4, 2016 at 8:09 PM
    uneaqs
    uneaqs New Member
    long time lurker, but i just broke two of those stupid rivets putting in a new stereo so finally had to sign up haha. poor form to be sure.
    ramonortiz55[QUOTED] likes this.
  11. Jan 4, 2016 at 8:10 PM
    ramonortiz55
    Ramon
    Texas
    stock
    what color and lengths of four gauge wire do you have? I need some for my winch setup..
  12. Jan 4, 2016 at 8:19 PM
    Caligula
    Los Angeles, CA
    How many do you need. I was expecting changing the door panel was going to be like it was on my BMW and break every clip. I only had to replace one of them. :)
    The heavy gauge terminals? Those were from Lowes, i think $6 or 7 for two. The yellow ones were around the same for the whole box. Make me an offer or 'interesting trade'.
    I REALLY want to get rid of some of these spade terminals lol.
  13. Jan 4, 2016 at 8:23 PM
    Caligula
    Los Angeles, CA
    I used that for my amp power and ground. Its heavy duty welders cable, good copper, not CCA shit. Ill check tomorrow how many feet i have, i think at least 6'.
  14. Jan 4, 2016 at 8:24 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Im always popping off the panels on my 3rd gen 4runner. Keep breaking them .. did these work for you on your 1st gen?
  15. Jan 4, 2016 at 8:25 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Thats what i need. Heavy duty for winching.
  16. Jan 4, 2016 at 8:25 PM
    Caligula
    Los Angeles, CA
    Yep, they worked as good as OEM. Auveco is old school body repair supply.
  17. Jan 4, 2016 at 8:26 PM
    FirstGen Jer
    Jeromey
    The 194 bulbs are for the instrument cluster, I have blue 5smd ones. But they are going out I need new ones. Also could use some sockets for the 194's as well? I need four of the 194's in blue. And one 74 in bright white?
  18. Jan 4, 2016 at 8:26 PM
    Caligula
    Los Angeles, CA
    And yes i can ship them, or you can pick up when youre in LA.
  19. Jan 4, 2016 at 8:30 PM
    Caligula
    Los Angeles, CA
    Ahh 194. Yes, those are the larger ones in the pic.
    $5 shipped i guess, if youre ok with me putting them in a envelope. Again since youre in socal, youre welcome to come and go through it and see what you want. I wouldn't mid as i would get to see how that 01+ bumper looks on your truck.
  20. Jan 4, 2016 at 8:36 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Ill probably buy the whole box lol. How many are in there? .50 each?
