Random tubing on 5vz-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaTaco23, Oct 12, 2013.
  1. Oct 12, 2013 at 10:05 AM
    YotaTaco23
    YotaTaco23 [OP] New Member
    Does anyone know what this random tubing is in my 03' Tacoma (5VZ-FE). It looks like it was once connected into a plugged tube off the intake.
  2. Oct 12, 2013 at 12:33 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    On my 02 it's hooked up to some sort of vacuum thing that doesn't let the throttle snap shut right away. But you have an 03 with throttle by wire, so you don't have one.It's meant to be a vacuum line to the TB for the 01 and 02
  3. Oct 12, 2013 at 1:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Hmmm...EGR??
  4. Oct 12, 2013 at 1:24 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    On my 03 and 04 it is just like yours. The pipe is not used and the cap is on the tube you pointed to on the right of the pic.
  5. Oct 12, 2013 at 9:17 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    My 2004 looks exactly like the picture the OP posted. Truck runs fine and the less hoses the better in my opinion.
  6. Nov 27, 2013 at 9:00 PM
    tacoma04
    Bruce
    Tennessee
    Ok, I'm obsessive and slow, but I found that this metal tube was used for meeting light duty truck tier 1 (LDT1) emissions standards. These standards were replaced by light duty truck tier 2 emissions standards and Toyota didn't use the tube to meet the new standards.
    So, it is a leftover piece.
    Black DOG Lila likes this.
  7. Nov 27, 2013 at 11:27 PM
    Hawaiian05
    Hawaiian05 Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    Yes, it was left unused from the factory so no need to worry. As far as the earlier comment, your 3.4 will not be throttle by wire, but standard cable operated. Throttle by wire didn't come out in tacomas till the 4.0 2nd gen.
  8. Nov 28, 2013 at 12:07 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And 2.7
    Funny that first gen Tundra technically had TBW from the first year, but still had a cable for '00-'02.
    The cable operated a sensor mounted to the TB, which told the ECU to open the butterfly.
    '03+ they went to 100% wire and eliminated the cable.
  9. Nov 28, 2013 at 12:16 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Not true. Drive by wire was introduced in the Tacoma's between 2003 and 2004. My dad's rocking a '04 Prerunner 3.4 with drive by wire.
  10. Nov 28, 2013 at 12:18 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    It was actually mid 2003 model year they went to that. My tacoma was a Dec '02 manufacture date but model 2003 with non drive by wire. It's got the cable to the pedal and cruise control/trans kick down (auto)
  11. Nov 28, 2013 at 12:26 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Tundra ;)
    My '03 was built in October '12, I put the first mile on it doing my test drive.
  12. Nov 28, 2013 at 8:17 AM
    Hawaiian05
    Tony
    Boise, ID/ Hawaii
    True. I was referring to "true" throttle by wire, as in not cable actuated in any way. When I wrenched for Toyota throttle by wire meant no cable bw gas pedal and throttle- strictly electronics. It was separated this way due to the ease of explaining recalls to customers who got worried over nothing.
  13. Mar 21, 2019 at 8:40 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Since this is the first post I found when I was searching for it, free bump!
    I came here after I was doing a normal inspection of my truck and noticed this sticker under the hood.
    I have the iECTS and my intake plenum has the unused tube as shown in the original post.
  14. Mar 24, 2019 at 4:46 PM
    LeMoine
    LeMoine Member
    I was always curious as to the purpose of these mysterious tubes!
  15. Mar 25, 2019 at 8:57 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    My 04 limited TRD off-road 3.4L is cable throttle, not drive by wore.
