Random vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChandlerISKING, Mar 8, 2018.
  1. Mar 8, 2018 at 6:52 PM
    ChandlerISKING
    ChandlerISKING [OP] Member
    Chandler
    08 Tacoma SR5
    I have been having a vibration that will randomly come up when im driving around 35 to 45 mph its not bad but noticeable and only last a few seconds at most ,any opinions would be great.
  2. Mar 8, 2018 at 7:18 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    From the center console or the passenger foot well?
  3. Mar 8, 2018 at 7:33 PM
    ChandlerISKING
    Chandler
    08 Tacoma SR5
    Seems like majority of it is in the dash. I can drive for a day it wont happen then out of no where it can do it a couple of times in a 30 minute drive.
  4. Mar 8, 2018 at 7:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you feel it in the seat of your pants it is probably a universal joint.
  5. Mar 8, 2018 at 7:42 PM
    ChandlerISKING
    Chandler
    08 Tacoma SR5
    Those will cause random vibrations. Its jist wierd that it always does it between 35 and 45 mph.
  6. Mar 8, 2018 at 7:45 PM
    81shark
    81shark Well-Known Member
    customer service program for driveline vibrations.. you should be getting a letter... worth checking..
  7. Mar 8, 2018 at 7:45 PM
    Pigpen
    Dan
    Northwest Montana
  8. Mar 8, 2018 at 7:50 PM
    Pigpen
    Dan
    Northwest Montana
    On a serious note, are you sure it isn't the differential bearing?
  9. Mar 8, 2018 at 7:52 PM
    ChandlerISKING
    Chandler
    08 Tacoma SR5
    I guess it could be. Ive seen alot of stuff where it says torque converter
  10. Mar 8, 2018 at 7:56 PM
    Pigpen
    Dan
    Northwest Montana
    The diff is a rhythmic hum. It's easily confused with the sound of MT tires.
  11. Mar 8, 2018 at 7:58 PM
    ChandlerISKING
    Chandler
    08 Tacoma SR5
    This is more of like going over a rough patch off road
  12. Mar 8, 2018 at 8:08 PM
    Pigpen
    Dan
    Northwest Montana
    Probably not the diff bearing. Mine was pretty tame. I've hard it described as running over rumble strips, but it's a rhythmic whir, whir, whir...
    I don't know anything about torque converters. I drive a 6 speed trans.
    ChandlerISKING[OP] likes this.
