Random wheel jerk and death wobble
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimbo219505, Nov 28, 2021.
  1. Nov 28, 2021 at 7:53 PM
    Jimbo219505
    Jimbo219505 [OP] New Member
    2020 white Tacoma trd
    6” readylift and 295s
    I’ve got 16k on my Tacoma, 10 of which it has been lifted. I’ve had some problems with the abs wire being pinched on the shocks but have fixed/replaced.
    I noticed a small wheel jerk, first thought it was a pothole but started noticing it on paved roads. totally random and can’t make it replicate. The wheel will jerk a quarter turn left, nothing that will cause an accident I doubt but enough to notice. Then at 45mph one day I experienced the steering wheel vibrating left and right some, it went away. Then it did it again and was way more violent. Almost death wobble ish. Then it went away and didn’t do it all the way home at 70 for 30 miles. I’ve shaken the hell out of the suspension, and everything seems as it should… new!
    I’ve seen some threads about a vsc malfunction? There are no warning lights on in the display.
    The only thing I can think of that was anywhere near the start of this problem is I rotated my tires at home. I also have a ripped boot on my passenger side cv axle, from a stick. Needs replaced yea but I’ve only pounded pavement for the last 6 months.
    many ideas? I fear I’ll take it somewhere and get deer in the headlight looks and spend a bunch of money on not being able to pinpoint the issue.
  2. Nov 28, 2021 at 7:55 PM
    Bishop84
    Bishop84 Well-Known Member
    A poor alignment and lack of caster can cause this.
    6" lifts usually are pretty easy for me to align to spec, but if there's a lack of caster or a loose control arm eccentric it will simulate a death wobble.
    Could be something loose, you need to check it out.
  3. Nov 28, 2021 at 8:08 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Maybe you’ve got a CV joint that is about to grenade.
    Knute likes this.
  4. Nov 28, 2021 at 8:19 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Who installed the lift? How many miles since then? Have you inspected anything? I have tons of ideas, but I don't think you want to hear any of them.
    Chew likes this.
  5. Nov 28, 2021 at 8:30 PM
    Jimbo219505
    Our company’s small truck mechanic installed the lift, and went back though it after 2000 miles. I have 10k miles since the lift and this problem started within the last 1000.
    I had a reputable tire shop do the alignment.
    I also had it on a lift and shook and rattled any component I can see, couldn’t find anything noticeable.
    Maybe another alignment at a different shop may find an answer…
  6. Nov 29, 2021 at 6:36 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Things like blown out control arm bushings or steering rack bushings/mounts are going to be pretty much impossible to detect by shaking parts with your hands. Especially the control arm bushings. With the vehicle off the ground the spring force against the topped out strut is preloading everything that pivots and with the wheels on the ground, the weight of the vehicle is going to move whatever is worn to its natural resting position. About the only things I have been able to feel with my hands are tie-rod ends, maybe wheel bearings and sometime ball joints, but you really have to put some ass into the wheel to move the ball joints usually.
  7. Nov 29, 2021 at 6:42 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check your wheel bearings.
    Get the truck in the air. Rotate the front tires by hand both forward and reverse. Listen for crunches or unusual sounds. Compare the force needed to turn the tire to the opposite tire. They should need about the "same" amount of force.
  8. Nov 29, 2021 at 6:55 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe that cv joint is binding up
  9. Nov 29, 2021 at 7:01 AM
    Sheld505
    Sheld505 Well-Known Member
    Michigan
    ‘22 DCSB SW SR5
    Tie rod? This was a problem with my ‘98 TJ…
