Randy Ellis cab mounted rock rails?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dumprat, Mar 9, 2017.
  1. Mar 9, 2017 at 10:24 AM
    dumprat
    dumprat [OP] Well-Known Member
    Southern B.C.
    08 tacoma DCLB
    TSB leafs, weather techs, ram mount,jack&shovel mount, and more to come.
    Anybody running these?
    I hate sliders with the stupid ankle bashing tube on the outside. I don't need or want side steps either. I just want something to protect the bottom edge of the cab from logs and rocks.
  2. Mar 9, 2017 at 10:42 AM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Isn't one of the main purposes of sliders to protect your rocker panels from getting FUBAR if you happen to come in contact with some trail nastiness?
    They kind of have to stick out a little bit otherwise you might as weld a chunk of steel to the bottom of the frame? Interested in opinions on this... :notsure:
  3. Mar 9, 2017 at 10:48 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Anything mounted to the cab isn't going to do anything to protect you from a log or a rock.
    Have you ever handled side steps? You stand on them and they flex. Your truck weight on a hard object is going to smash them into your rockers.
    They literally bolt into a piece of sheet metal.
    eccracer104 and TACOVRD like this.
  4. Mar 9, 2017 at 10:55 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    ^^^This.
    The N-Fab steps I had on before my sliders were held on by a total of five 8mm x 1" bolts. If you want to protect your truck from legitimate trail damage, you need sliders that bolt or mount to the frame.
  5. Mar 9, 2017 at 10:56 AM
    T4RFTMFW
    Get shorter sliders made. ;)
  6. Mar 9, 2017 at 10:58 AM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    What you want are frame mounted rock sliders without a kick out. Anything mounted to the cab will not protect your truck from a rock or log, cab mounted is strictly to be used as a step bar or for the looks.
  7. Mar 9, 2017 at 12:37 PM
    dumprat
    Southern B.C.
    08 tacoma DCLB
    I have had steps, sliders, rock rails and have a pretty good idea of what I want thanks. I just asked weather anybody had tried the the Ellis rocker rails.
    I realize these are fairly different product, everybody else's sliders look the same. My experience with the tube rails is just mud catcher and step.
  8. Mar 9, 2017 at 12:45 PM
    Irongrave
    Irongrave Well-Known Member
    Drew
    Knoxville TN
    1998 T4R Limited
    If you are not wheeling in an area where you need the kick out to keep the body off rocks the would work. I do like how sleek they look without the rub rail. However for most users that need sliders the rub rail is to keep the body off rocks/trees or used as a pivot point and the extra kick out is to keep the bed sides from kissing what is ever on the trail.
  9. Mar 9, 2017 at 12:49 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    That's a lot of holes that need to be drilled into the body. Even with that many rivets holding it on, I'm still really apprehensive about the strength of those sliders. It looks like you're asking for a lot of body damage if you ever actually use them off road.
    If you just want them for steps and protection from parking lot dings, I think they look great.
    eccracer104 and T4RFTMFW like this.
  10. Mar 9, 2017 at 3:50 PM
    dumprat
    Southern B.C.
    08 tacoma DCLB
    Rivets and brace I got add a lot of strength to what is usually a weak point of the body. You guys eve built a snowmobile or an aircraft? Rivets are great if done right.
    Again back to my original question.
  11. Mar 9, 2017 at 4:00 PM
    i_cappi
    i_cappi Well Known Membhair
    Canton, Oh
    2011 TX TuRD Pyrite DCSB
    Snowmobiles and aircraft are not slamming down 2.5t of weight onto rocks.
  12. Mar 9, 2017 at 4:57 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    This style of slider is not big on TW. Probably because no one wants to put holes in their truck body.
    Another fab outfit has a similar design, maybe Rocky Mountain outfitters or something along those lines. Don't remember hearing anything good about them. Same idea, they tout this design as supreme to welded on sliders. Usually every once in a while some guy comes along saying they are the best design since sliced bread like you (no offense). And maybe they are Idk, but not enough people run them to make it known, and the price is way higher than the "traditional" offerings the Toyota crowd goes with.
    Bolt ons are now more popular and have more offerings, and I think most people want to go with what's least invasive unless they are building a rock crawler which at that point who gives a shit about form, and function becomes the goal.
    In short I don't think you will find anyone on here running these. I'd love to see you go for it an find out. Seems some of the 4Runner guys on t4r run them.
  13. Mar 9, 2017 at 6:19 PM
    dumprat
    Southern B.C.
    08 tacoma DCLB
    Ya I suppose.
    Most forums tend to develop a hive mind and anything outside the box is shunned. I am pretty used to this .
    Carry on! I will figure it out.
