Range E tire pressure
Discussion in 'Wheels & Tires' started by tacoVee, Mar 22, 2021.
  1. Mar 22, 2021 at 10:56 AM
    tacoVee
    tacoVee [OP] New Member
    Pat
    Hello my fellow Tacoma people! First time posting on here, although I've read a lot through this forums and it has been quite helpful so far.
    I just got some 255 80 17 (10 ply) wildpeaks installed yesterday and I was curious what others running a similar setup have set their tire pressure at?
    Thanks in advance for your feedback, cheers!
  2. Mar 22, 2021 at 10:57 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Chalk test is your best bet to be sure
    doublethebass, whatstcp and Dacapster like this.
  3. Mar 22, 2021 at 10:59 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I've never chalk tested, but i run 35-37 up front and 33-34 in the rear. I'm loaded - skids, bumpers, sliders, winch, batteries.
    offroad, i drop to 22-25 usually
    ST MAXX's - 285/75/16
    Truck weight loaded - 6400lbs
  4. Mar 22, 2021 at 11:02 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    32psi on 265/70R17 Toyo RT.
    Even wear, comfy ride, happy TPMS.
    I'll pump them up to 38 when I hook on the RV.
    71tattooguy likes this.
  5. Mar 22, 2021 at 11:13 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I run in between 30 - 35psi e rated Yokohama x-at off-road 18 - 20
    Oatwillie and Hooper89 like this.
  6. Mar 22, 2021 at 11:16 AM
    TACO Padre
    TACO Padre The wise man thinks twice and says nothing.
    Colin
    West Coast
    2016 Limited
    Seat Spacer, Sprint Booster, Bilsteins 6112.5100, AAL,
    37 psi 10ply
    Flori-duh Taco likes this.
  7. Mar 22, 2021 at 11:23 AM
    tacoVee
    Pat
    Yeah I'm planning on doing that shortly. I was just curious to see what others were running. Thanks!
  8. Mar 22, 2021 at 11:23 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    im 285\75\16 km3 10ply E rated here where i live with the temps in the morning cold tire is at 35psi when down the hwy 30min tire psi is at 38 psi warm tires if it gets 60F then it can be up to 41 psi
  9. Mar 22, 2021 at 12:48 PM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Chalk test is useless. Use a load inflation table provided by the tire manufacturer. Shoot them an email and they will give you what you need. For that tire size and load rating on a Tacoma, it will be around 36PSI to 40PSI.
    Here is Toyo's for reference:
    How to apply the load inflation tables (toyotires.com)
  10. Mar 22, 2021 at 1:33 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    35 psi. Be prepared for a very harsh ride at that psi with E tires.
    if you don’t mind mushy handling and being unsafe, then run 20-25 psi for a much softer ride.
    b3itz likes this.
  11. Mar 22, 2021 at 1:35 PM
    shotgunbilly420
    Wonder if bfg has this on their site
  12. Mar 22, 2021 at 1:36 PM
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    damn.... I'm running 45 front and 50 back unloaded. Add RV and I go to 55. E tires suck but so does a 6" lift pulling an RV with a Taco getting 5 MPG sometimes 9.
    My tires are rated up to 80PSI. Never felt the need to check that out but in the 35 PSI range it was like riding on flat tires.
    05tacomabro and Flori-duh Taco like this.
  13. Mar 22, 2021 at 1:53 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'm no scientician, but that seems like an awful lot.
    Vitamins, G2.M6, b3itz and 2 others like this.
  14. Mar 22, 2021 at 1:55 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
  15. Mar 22, 2021 at 1:56 PM
    Gatordog
    Florida
    agree but.... I ran around for the first 10k miles at the dealership set 30-35 and the drive sucked. The are huge wheels and tires and I have been way more happy with higher PSI which is still 30 PSI below max.
  16. Mar 22, 2021 at 2:00 PM
    Gatordog
    Florida
    OP just so you know please follow what you are comfortable with and what setup you have. For the record, I have a 6" lift. 20 inch wheels and these E rated tires
    Pro Comp Xtreme MT2 LT35X12.50R20 (Load E) $1788
    PCT701235
  17. Mar 22, 2021 at 2:39 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Ahh, 20's
  18. Mar 22, 2021 at 2:40 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    P-metric and euro-metric are inflated to 2,149 lbs.
    LTs are inflated to 1,954 lbs.
    LT255/80/17 gets 1,983 lbs @ 36 PSI.
  19. Mar 22, 2021 at 3:06 PM
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    FinnJ and BC Hunter like this.
  20. Mar 22, 2021 at 3:08 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Lol to everyone rolling on rocks.
