Range E tire pressure
Discussion in 'Wheels & Tires' started by tacoVee, Mar 22, 2021.
  1. Nov 14, 2024 at 6:47 PM
    #41
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    3 different trucks 305/65r18, 285/70r17, 35/12.50r17, 255/85r16, 285/75r16 all e load rating all ran 32-34psi never had any issues.
  2. Dec 2, 2024 at 7:09 AM
    #42
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    My AT4W Falkens are pretty hard compound (HD load E) and ride rough even at low PSI. How’s the X-AT? Is the ride somewhat comfortable?
  3. Dec 13, 2024 at 10:04 AM
    #43
    Cooljohn253
    Cooljohn253 Active Member
    Boise, ID
    2012 MGM SR5 ACLB
    Basically anything cool I could get my wife to buy for me and small cheap stuff I could do when I get bored. Swapped for a hood scoop Deleted mud flaps ECGS Front diff bushing 2 inch RC spacer level, 1/2 inch Toyota level block Cali Raised bed stiffeners Taco net cargo net thing Alpharex Pro headlights, fog lights, luxx tail lights Fog light anytime mod Yellow wire mod v2 Undercover Flex cover Meso customs dual color interior lights Connect map lights to dome mod OEM TRD Pro wheels in grey Geolandar X-AT 285/70R17 (33 ish) for summer Nokian Hakkas on stock wheels for winter Trimmed front bumper slightly to push fender liner forward Heritage grill and painted grill surround JBL Stage door speakers and DS18 tweeters Converted bcm back to using a flasher relay using Toyota jumper to add smart tap relay With Caribe's help built a harness to convert back to 05-11 trailer combiner and tie in my smart tap, basically reverting all turn/brake to older style Pop n lock wired to passenger door unlock wire to open on 2nd click Wired passenger door unlock to driver door for one click unlock Added tie downs to bed bolts TRD off road take off rear shocks from a 2019 Debadged
    They're my only baseline on what an e rated all terrain is like. I would say it's certainly not unbearable with decent roads and on the highway, aired down they're awesome.. I do feel basically every bump and manhole cover on surface streets but I have 150k on stock sr5 front coils and a spacer lift, about 60k on rear trd off road take offs so I'm not doing it any favors.
  4. Dec 14, 2024 at 3:16 AM
    #44
    TacoRancher
    Houston
    Just took my AT4Ws in some intense rocky stuff and man.. they are tough as balls. Need to figure out how I can keep them and switch easily to standard loads tires whenin town.
  5. Dec 14, 2024 at 8:23 AM
    #45
    Cooljohn253
    Boise, ID
    2012 MGM SR5 ACLB
  6. Dec 14, 2024 at 8:24 AM
    #46
    Cooljohn253
    Boise, ID
    2012 MGM SR5 ACLB
    In all seriousness though how well does the 4th gen push them?
  7. Dec 14, 2024 at 8:40 AM
    #47
    TacoRancher
    Houston
    super easily
