Ranger Bed Extender on 2nd Gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by friction, Jun 22, 2011.
  1. Jun 22, 2011 at 6:04 AM
    friction
    friction [OP] Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Hi all - Has anyone attempted to mount a late model Ford Ranger OEM bed extender on a 2nd gen Tacoma? I have my 2005 Ranger extender up on Craigslist as I have a Tacoma ordered...now I am second guessing myself and think maybe I should pull it off until I try to mount it.
    Thanks!
  2. Jun 22, 2011 at 10:58 AM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    Extang Trifecta, LED Console lighting, VentShades
    A friend just gave me an extender from his 2003 Nissan Frontier. It seems to fit just fine. I had to order the brackets and the strap kit for the Tacoma, but havn't come in yet.
    Most if not all factory extenders are made by Amp Research.
  3. Jun 22, 2011 at 12:29 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Thanks Fagro...that is good news! Guess I'll remove my craigslist ad and hope it works when my truck arrives.
  4. Jun 22, 2011 at 12:32 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    I'm pretty sure you are correct...perhaps just the mounts vary in length. If it is only an inch or two wider I might be able to adapt with Ford mounts and some washers for length on the mounts.
  5. Jun 22, 2011 at 12:33 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    the taco bed is like an inch or two wider near the tail gate if that matters to ya.
  6. Jun 22, 2011 at 12:34 PM
    BMOC
    Paden
    Phoenix, AZ
    there ya go
  7. Jun 22, 2011 at 12:48 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    I might be able to work with that...I'll investigate whether it is actually the same bed extender. Here is a pic of it on my current truck and a pic of the connecting mount:
  8. Jun 22, 2011 at 12:56 PM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Ah, ok...thank you. Toyota's OEM hardware certainly won't work then...I still have the mounts, so I'll have to see if I can make Ford's mounts work.
    Thanks for the help!
  9. Jun 29, 2011 at 6:25 AM
    xxaarraa
    xxaarraa Well-Known Member
    Many of the bed extenders have interlocking tubes that can be adjusted in length. I got a bed extender off a Nissan Titan and was easily able to shorten the width to fit the Tacoma. Check it out,
  10. Jun 29, 2011 at 9:06 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Thank you for the reply. Mine is OEM and specific to the Ranger w/no adjustments...it is slightly flexible, so it can be adjusted a bit when hooking into the pins. I am still waiting on my truck to arrive (Carmax says 21 days, which puts me a week out still), but I will hopefully be able to rig something up. I'll put an update in this thread.
  11. Jul 5, 2011 at 7:57 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Well, the answer to my original post in one word is "no." I could not quite make it work. I suppose with fabrication skills and proper tools I could do so, but too much for me.
  12. Jul 15, 2011 at 7:16 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Further update and correction...I think I can make it work. Come to find out that the bolt extending from the bed of the Ranger (OEM mounting equipment) is actually a striker bolt...I just bought some longer ones, and will try to mount with nuts attached inside the tail lights plus some washers to get the perfect length...I'll let you know how it goes.
  13. Aug 19, 2011 at 7:11 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Ok, the above method worked...required 5 washers for the fit.
  14. Aug 19, 2011 at 7:23 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    Looks good and glad you made it work :thumbsup:
  15. Aug 19, 2011 at 7:25 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Thanks! Saved some bucks as I need an extender for my extended camping trips (especially with the toolbox). I always liked the finish of this extender anyway.
  16. Oct 27, 2011 at 7:00 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Ok, these measurements are approximate:
    Bed to top of bolt: 8 3/4"
    Bed to bottom of bolt: 7 "
    Diameter of bolt head: 3/4"
    In the first picture you can see that it is certainly wider than the bed of the Ranger. BTW, you could easily lower it another 1" and still have clearance (I think I mounted it a bit too high, but it works fine).
  17. Nov 21, 2011 at 8:51 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    And here is why I did it. :D
  18. Jul 22, 2015 at 12:40 PM
    Tacomaholic06
    Tacomaholic06 New Member
    2006 White Tacoma
    Leveling Kit
    Hi I'm having the same issue. My friend gave me a bed extender from his ranger he sold and I was wondering where and what part's did you have to get to make this work for you (friction)
    Thank you in advance
  19. Jul 23, 2015 at 8:39 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    They are called door striker bolts (used for auto doors). I can't remember the exact link, but I measured the length needed by placing the extender in the center of the tailgate. I picked them up at the auto parts show. They were not quite long enough, so I just added washers to each make them reach further. I bolted the threaded part of the bolt through holes I drilled into the taillight housings (see pictures above for location).
    Again, I don't know the exact length but it looks like this:
    $10 Dorman 38421 Door Striker Bolthttp://www.amazon.com/Dorman-38421-...8&qid=1437665518&sr=1-4&keywords=striker+bolt
  20. Dec 16, 2015 at 11:41 AM
    Hadeze
    Hadeze Member
    1997 Blue Toyota Tacoma SR5
    K&N intake
    Friction, what did you do about the pin bolts; how did you make them work?
