Rapid rear tire pressure increase when towing
Discussion in 'Towing' started by soggyBottom, Feb 25, 2025.
  1. Feb 25, 2025 at 8:08 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    When towing I've noticed my rear tire pressure jumps about 5psi more than my front tires. front and rear start at the same cold pressure. This has happened several times now.
    Is this normal? 5psi more than the front seems like a lot. tongue weight is probably around 400lbs.
  2. Feb 25, 2025 at 8:35 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s normal. You’re putting more load in the tires so they heat up faster.
    ColoradoTJ likes this.
  3. Feb 25, 2025 at 8:45 PM
    2013TuRD
    2013TuRD Well-Known Member
    Bruce
    SW BC
    TRD OFF ROAD
    5 psi is nothing to worry about.
    Two strategies if you must worry about it.
    1. Raise the starting pressure and you will get a smaller pressure rise. A tire that flexes less will build up less heat and therefore have less pressure rise.
    2. (and I don't recommend this) lower the pressure, accept an even bigger pressure rise and arrive at your desired end pressure during operation.
    My method is to set the hardest tire pressure that rides acceptably, and then check the tire temps after an extended freeway run. Tires should not be hot to the touch unless you're on a race track.
    1 Limited Toyota likes this.
  4. Feb 26, 2025 at 8:50 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    I've always run max. pressure with no wear issues. Our 100*+ summers here in central Ca. raise pressure but an add on TPMS has not only pressure shown but setable heat, pressure and rapid pressure loss alarmed parameters.
