Rapid turn signals
Discussion in 'New Members' started by Sightseer, Dec 24, 2020.
  1. Dec 24, 2020 at 11:39 AM
    Sightseer
    Sightseer [OP] New Member
    2014 Toyota Tacoma TRD Charcoal grey
    LED Lights and signals
    The truck has LED aftermarket lights and signals. Does anyone know if I can get a turn signal flasher designed for LED lights that will plug into original fuse box receptacle. 2014 Tacoma TRD
    buckhuntin-tacoma likes this.
  2. Dec 24, 2020 at 11:40 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Yes you can
  3. Dec 24, 2020 at 11:42 AM
    Black DOG Lila
    Virginia
    But I don't think the flasher module is in the fuse box.
    I could be wrong.
    It's separate on 1st gens
  4. Dec 24, 2020 at 11:44 AM
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    I believe you can also add a resistor so the system doesn't see the drop as a burned out bulb.
  5. Dec 24, 2020 at 11:48 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila likes this.
  6. Dec 24, 2020 at 11:50 AM
    Ianwrx
    Ianwrx New Member
    Ian
    2016 Subaru wrx
    Stage 2+
    You can google, fast blinker module and a bunch of info comes up. Parts, videos ect.
  7. Dec 24, 2020 at 11:52 AM
    slodoug
    slodoug Well-Known Member
    several threads on here about led flashers. 1st gen in tucked up behind fuse box, hard to reach so you may have to feel it. i got all my lights and flasher relay at https://www.superbrightleds.com
  8. Dec 24, 2020 at 11:54 AM
    Sightseer
    I'm a rookie on this, so please bare with me. Black dog, can I buy the flasher module for LED at a local parts store or online?
  9. Dec 24, 2020 at 11:56 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    daveeasa likes this.
  10. Dec 24, 2020 at 11:56 AM
    Sightseer
    My bad, I see responses with info links from other members. Thanks for all of your help everybody
  11. Dec 24, 2020 at 11:56 AM
    Black DOG Lila
    Virginia
    Most parts stores have online inventory check
    Online for sure
  12. Dec 28, 2020 at 5:54 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  13. Dec 28, 2020 at 6:23 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4
    Overbuilt daily driver
    @Sightseer, no one makes a LED flasher unit for DTRL (daytime running light) equipped 2nd gens. They use a 12 pin connector, which is different from the non-DTRL 8 (?) pin flasher unit. Since you have a newer 2nd gen, you probably have a 12 pin flasher. Your only options are soldering in a resistor or switching the LED bulbs back to the stock incandescent bulbs. Since resistors are pretty failure-prone, I'd personally go back to stock.
    *Edited to add: I'm not a Tacoma expert, and I am a certified electrical idiot. I could very well be wrong about the above.
    I do wish someone would come out with a 12 pin LED flasher unit. I'd love to swap my stock bulbs for LEDs.
