Raptor light fuse help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by StupidmonkeyzZ, Apr 17, 2021.
  1. Dec 6, 2021 at 6:57 AM
    #41
    Sweenbeen
    Sweenbeen Member
    2020 Taco - Vudu Blue
    I am having trouble locating one. My truck has a push to start & I thought the radio fuse would work, however it seemed like that was always on. I will check the power port fuse.
  2. Dec 6, 2021 at 9:51 AM
    #42
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I believe the radio is always drawing a little bit of power to keep the clock running and your radio presets saved.
    The INJ fuse has worked well for me so far.
  3. Dec 7, 2021 at 10:52 AM
    #43
    Sweenbeen
    Sweenbeen Member
    I will give that a try shortly. I am hoping this will take care of it though!
  4. Dec 8, 2021 at 12:16 PM
    #44
    Sweenbeen
    Sweenbeen Member
    Well, using the INJ fuse worked perfectly. Though I do, tbh, have concerns with loading it into the fuel injector fuses... I think it will be fine! I just wish there was another fuse that was a little less catastrophic if it goes bad.
  5. Feb 18, 2022 at 5:13 PM
    #45
    Moving_overland
    Moving_overland New Member
    Tacoma trd pro 21
    So looks like hlp is about the only way to go where the panel turns off with the truck.
  6. Feb 18, 2022 at 7:04 PM
    #46
    Hockey71
    Hockey71 Well-Known Member
    Jacob
    Hockeytown, Detroit, Michigan
    2021 TRD Sport
    I wired mine through to come on with my headlights. Good idea so they aren't always on while you're driving in daylight, unless that's what you want.
  7. Jul 4, 2022 at 9:44 AM
    #47
    Tacoma07SR5
    Tacoma07SR5 Active Member
    2007 Desert Sand Tacoma SR5
    With the add a fuse connected to the 10amp ETCS it doesn’t have that problem that the lights will randomly come on when truck is off? I want to set up mine running while truck is on but I don’t wanna mess with the fuel injectors or ignition fuses. I tried connecting into power outlet fuse but wires aren’t long enough.
  8. Jul 4, 2022 at 11:21 AM
    #48
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    This is what I did.
    Hockey71[QUOTED] likes this.
  9. Aug 27, 2022 at 4:02 PM
    #49
    LiquidDayno
    LiquidDayno New Member
    2019 Voodoo Blue TRD Pro
    So I had plugged mine into the INJ fuse just as well, ran without issue for a year. One of the lights/connections was faulty and tripping the breaker... Shutting down my truck while driving and not being able to start again. 20 mins of internet searching and I tried the INJ fuse back to normal config, starts up and we are good to go. Removed the add-a-fuse and relocated it to the headlights fuse. One of the lights was flickering, took care of that by removing it, but it was strange.
    Just a word of caution if you choose to use the INJ fuse. Could be a potential safety hazard.
