Raptor lights, power source.
Discussion in 'Lighting' started by Rendermandan, Dec 26, 2019.
  1. Dec 26, 2019 at 5:19 PM
    Rendermandan
    Rendermandan [OP] Member
    Dan
    White 2020 TRD PRO.
    Raptor lights. That’s it, don’t laugh... :)
    For Xmas I received a set of raptor style lights for my 2020 TRD Pro. I got the lights installed and wiring ran to ground and into the fuse box. It seems most people hook the power line up to either the left or right headlight low beam fuse. 10 amp down in front left of the fuse box. Circled red in the image. This works however, if you use your high beams or turn your headlights off, the raptor lights turn off. Plus, I can’t use the driving lights from the headlight because Of the sequential turn signals.
    So my solution was to test other fuses for switched power. It seems there is a 10 amp fuse labeled EFI NO.3 circles in blue that is ignition controlled. With the raptor lights pugged into there, they stay on no matter what the headlights are set to, and are on whenever the truck is running.
    Does anyone see any problems with running the lights from this fuse?
  2. Dec 26, 2019 at 6:23 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    I would absolutely NOT use the EFI fuses. Those power the EFI Main relay, which in turn powers the fuel pump, ignition switch, and starter relay. In some cars they power the ECM computer. If that fuse blows, you're truck is dead in the water.
    tirediron and caribe makaira like this.
  3. Dec 26, 2019 at 7:58 PM
    Rendermandan
    Dan
    White 2020 TRD PRO.
    Maybe I should have mentioned, it’s connecting to the fuse box with an adapter that came with the lights set. You replace the fuse with the adapter that then has two fuses. One for the original circuit, and one for the new lights. So they are on separate circuits, but pulling from the same “switched” power slot in the fuse box.
    looks like this.
  4. Dec 27, 2019 at 4:21 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I still wouldn’t mess with the EFI/ECU stuff.
  5. Dec 27, 2019 at 6:09 AM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    I used to have mine run through the ignition fuse (whichever that is). They were always on when the truck was on, had absolutely no problem with it. Just switched to have them ok with the low beams now.
  6. Dec 29, 2019 at 1:22 PM
    caribe makaira
    Caribbean, Puerto Rico
  7. Dec 29, 2019 at 3:18 PM
    Rendermandan
    Dan
    White 2020 TRD PRO.
    So would that be a better fuse to use?
  8. Dec 29, 2019 at 4:22 PM
    caribe makaira
    Yes
    All others are either always "HOT" or have other "effects" (like pump test after all off, leading to turning ON any circuit tied into it) EFI No.3 does that...
  9. Dec 29, 2019 at 5:50 PM
    CWO35
    CWO35 Active Member
    Don
    2019 Tacoma TRD PRO
    Stock for now.
    I just got these myself - my question is, how did you run the wire into the fuse box? Did you drill a hole for the wire? I apologize if this is a stupid question...
  10. Dec 29, 2019 at 5:53 PM
    Rendermandan
    Dan
    White 2020 TRD PRO.
    No, don’t drill a hole. I watched a you tube video that shows how to remove one of the wire harnesses that comes into the box. I fed the wire through that existing opening, then replaced the existing wire harness.
    I can’t remember the video though.
  11. Dec 30, 2019 at 6:27 AM
    CWO35
    CWO35 Active Member
    Don
    2019 Tacoma TRD PRO
    Stock for now.
    Thanks, I found a couple videos.
  12. Dec 30, 2019 at 7:45 PM
    codyb209
    codyb209 Well-Known Member
    robert
    209-916
    2019 TRD off road
    What do you mean by this?
  13. Dec 30, 2019 at 9:03 PM
    Rendermandan
    Dan
    White 2020 TRD PRO.
    The 2020 head lights have driving lights that turn into Amber sequential turn signals. So if I wire them to the driving lights, when I put my turn signal on, the raptor lights will turn off.
    codyb209[QUOTED] likes this.
  14. Jan 18, 2020 at 6:59 AM
    J bug
    J bug Well-Known Member
    Jeremy
    GTA
    2019 Trd pro
    19 TRD PRO REVTEK 1.5" LIFT BORA 1.25" WHEEL SPACER '20 TRD PRO TAIL LIGHTS W/ MESO TOTAL STAGE 1 LED LIGHTS MORIMOTO 2STROKE LED HEAD LIGHTS RUNNING4TACO RAPTOR LIGHTS MESO MAP/DOME LIGHTS MESO FULL CABIN CHROME DELETE LEER XQ CAP BIG COUNTRY CUSTOMS BED STIFFENERS
    What brand/ link ? of lights did you get
  15. Jan 18, 2020 at 7:02 AM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    There’s a thread on here somewhere about those lights interfering with the DRL and actually burning them out. I’d be careful on the wiring.
  16. Jul 4, 2022 at 8:28 AM
    Tacoma07SR5
    Tacoma07SR5 Active Member
    2007 Desert Sand Tacoma SR5
    would the power outlet fuse be good for the raptor lights to be on when truck is on and off when truck is off key out of the ignition. I don’t wanna mess with fuel pump or ignition fuses. My 2 gen doesn’t have INJ so I think power outlet fuse would be good right?
  17. Jul 4, 2022 at 8:46 AM
    caribe makaira
    Sure.
    But on the 2nd Gen you have a fused ign source in the engine bay fuse/relay box.
  18. Jul 4, 2022 at 8:52 AM
    Tacoma07SR5
    well I could put it on the power outlet fuse if my wires were long enough. But what would you recommend to put the add a fuse in for the raptor lights? ETCS 10 amp fuse would be good? I’ve heard it works the same as INJ.(2 gen doesn’t have INJ fuse) Which means it shouldn’t turn on randomly when off if I put it ETCS fuse. Apparently it’s the multi port fuel injectors fuse.
  19. Jul 4, 2022 at 9:00 AM
    caribe makaira
    IGN tap from under/inside the engine fuse box
  20. Jul 4, 2022 at 2:24 PM
    Tacoma07SR5
    I’m thinking on connecting the add a fuse to the ETCS 10 amp. Do you know if that also does those self pump test when vehicle turned off?
