RAPTORS LIGHTS ON WHEN TRUCK IS OFF
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VANGUY24, Aug 13, 2020.
  1. Aug 13, 2020 at 9:02 AM
    VANGUY24
    VANGUY24 [OP] Member
    Daniel
    2019 toyota tacoma
    I have a 2019 Tacoma TRD OR and have recently installed raptor lights. i noticed a few days ago that randomly the lights come on and off when the truck is not running/locked. My main concern is the battery being drained but i would like to know whether i should have other concerns. For reference i used the 10 amp EFI NO.3 as many youtube tutorials suggested. I am open to unplugging it immediately if this can cause more troublesome issues. Looking forward to some feedback.
  2. Aug 13, 2020 at 9:07 AM
    Tacospike
    Two Trucks
  3. Aug 13, 2020 at 9:11 AM
    calebc
    calebc Well-Known Member
    That may be getting power when the recycle process kicks on, which would explain the random on/off.
  4. Aug 13, 2020 at 9:13 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Rule#1 Don’t tie aftermarket accessories into engine management circuits.
    Grindstone, pdaddy, Tacospike and 3 others like this.
  5. Aug 13, 2020 at 9:24 AM
    VANGUY24
    Daniel
    2019 toyota tacoma
    Okay are you saying don't use the raptor lights at all? i appreciate the response but can you elaborate.
  6. Aug 13, 2020 at 9:28 AM
    calebc
    You're pulling power from a system critical circuit. If those Raptor lights are cheap Chinese ones (I don't know of any that aren't) I would NOT have them on a critical circuit and in a perfect world, would not be off any existing circuits. Create a new, properly isolated circuit for them. But yes, I would also not use Raptor lights at all either :)
    VANGUY24[QUOTED][OP] likes this.
  7. Aug 13, 2020 at 9:32 AM
    JeepinDoug
    JeepinDoug Active Member
    Doug
    2019 TRD Pro Tacoma
    none
    One of these threads say tapping into engine components gives you this condition.
    I did that and get the same thing, several hours after parking they may come on for a minute or so,
    Once I did see they came on and stayed on too long, so I unlocked the truck and locked it and they went off after a minute.
    Runnin4tacos has a wiring harness developed by Meso that taps into the light harness and eliminates this condition.
    https://www.runnin4tacos.com/produc...ess-toyota-tacoma?_pos=1&_sid=885d1f52b&_ss=r
    MESO likes this.
  8. Aug 13, 2020 at 9:33 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    This happened to me too at the recommendation of the place I purchased them from.
    Tap into the DTRL.
  9. Aug 13, 2020 at 9:36 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I made the same mistake. There is an injector fuse and efi injector fuse. Don’t tap into the efi injector fuse or the raptor lights will turn on after the engine had shut down to perform the emission test thing.
    Grindstone likes this.
  10. Aug 13, 2020 at 10:17 AM
    ToyodaTruck
    ToyodaTruck Well-Known Member
    2019 TRD Sport
    Thanks for the tip and link. I'm going to order one.
  11. Aug 13, 2020 at 10:23 AM
    VANGUY24
    Daniel
    2019 toyota tacoma
    Thanks! which fuse should i tap into then?
    Hoofer likes this.
