Rarely used 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by okccj, Aug 31, 2018.
  1. Aug 31, 2018 at 7:21 AM
    okccj
    okccj [OP] Well-Known Member
    I have a 17 TRDOR auto trans. I only use 4WD during hunting season, thus I haven't turned it on in about 11 months. Also, I've never used 4 Lo or any of the crawl control stuff. My question is, should I periodically turn these features on (like in a parking lot), or is there no harm in letting them set dormant for long periods of time?
  2. Aug 31, 2018 at 7:26 AM
    DuraTaco
    DuraTaco Active Member
    Bryce
    Austin, Tx
    I think the manual recommends driving it in 4WD 10 miles a month or something like that. I live in Austin where there isn't much public land or even random dirt roads to get the 4WD going so I've just accepted the fact I'll have an expensive fix at some point in the future because I don't use it enough.
  3. Aug 31, 2018 at 7:27 AM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    They should be exercised monthly to prevent the actuators from locking up. When I first bought my 4Runner (used) it wouldn't go into 4LO because the prior owner never used it. Luckily it started working after months of trying unsuccessfully to get into 4LO.
  4. Aug 31, 2018 at 7:29 AM
    okccj
    Can I just turn it on 4HI, 4LO, Craw Control, locking diff in a parking lot and slowly drive with it on for a few seconds?
  5. Aug 31, 2018 at 7:29 AM
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    On straight aways on the highway, simply put it to 4hi, after a few miles and before a turn, go back to 2hi. Do that one or twice a month and you’ll be fine.
    InfernoTonka and TFly like this.
  6. Aug 31, 2018 at 7:30 AM
    fdbyrne
    Missouri
    There's nothing magical about the 10 mile figure. Driving it a certain number of miles isn't necessary. It's really only the engagement and disengagement that needs to happen. I usually just do mine in the neighborhood on paved roads. The key is to do it in a straight line. I go into 4HI drive 100 feet or so, put it in 4Lo drive another hundred feet, then back to 4HI, then 2HI. It only takes a minute or two.
    InfernoTonka likes this.
  7. Aug 31, 2018 at 7:31 AM
    phsycle
    phsycle Well-Known Member
    CA
    I don't think you need to do it every month, necessarily. I would just try to do it every now and then. I probably do it every other month on the off-seasons. If you don't have a dirt road nearby, just drive straight with 4WD engaged.
    stun gun likes this.
  8. Aug 31, 2018 at 7:31 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    ^^^^^This.
    G.
  9. Aug 31, 2018 at 7:33 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Running it in 4Hi on paved roads will not cause immediate destruction, just don’t make tight turns, you will feel it fighting you when you turn too sharply. I switch in 4 low once in a blue moon going up my driveway.
    InfernoTonka and mjc251 like this.
  10. Aug 31, 2018 at 8:29 AM
    securekey
    securekey Well-Known Member
    2018 TRD Off-Road DCSB - Blazing Blue
    Good questions and answers... no one addressed the crawl features. I assume they just control 4lo and the braking system for traction. They must be electronic so need to use those specifically as long as you are using 4 high and 4 low?
  11. Aug 31, 2018 at 8:34 AM
    Durango95
    Durango95 Well-Known Member
    Great North Woods of Wisconsin
    17 QSTRDOR4x4ACATFTMFW
    Sounds like a good reason for a road trip to find some dirt!
    specter208 likes this.
  12. Aug 31, 2018 at 8:35 AM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    Part of my commute is about 14 miles of straight interstate. Every once in a while I’ll put it in 4WD for that stretch.
  13. Aug 31, 2018 at 8:40 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    The important stuff was already covered I think. Just to mention, OP asked about crawl control as well. I don't believe there is any advantage to exercising crawl control. The truck electronically manipulates the throttle (already drive by wire), and independently operates the brakes. The brake master cylinder hydraulic pump is already exercised by driving, so it would just be additional exercise of solenoids in the brake circuit. I wouldn't bother.
    Also, there may be some value in exercising the rear diff, but it will be much less than the old 2nd gen and previous design. I wouldn't bother with exercising the rear diff as often as the rest of the 4wd system...
    tonered likes this.
  14. Aug 31, 2018 at 8:48 AM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    IN Texas!!!!??? I find that hard to believe -- just drive farther out of town --Lordy --Texas is a BIG state. I remember it well from 6 weeks in San Antonio and another 9 months in San Angelo
    Durango95 and stun gun like this.
  15. Aug 31, 2018 at 8:49 AM
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    16 years of driving my old tundra and I only locked it in a few times during hunting season and never had a problem.
  16. Aug 31, 2018 at 8:52 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Agreed.
    No room in Texas? You’re doing it wrong.
    Durango95 likes this.
  17. Aug 31, 2018 at 9:20 AM
    ChronicTaco
    ChronicTaco Well-Known Member
    British Columbia
    Canadian Special
    Easy solution, plan a wheeling trip every month!
    BlakeM and Durango95 like this.
