Rate my 2nd gen Lower control arm Bushings.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdtemple, Feb 15, 2011.
How do these bushings look?
Poll closed Jun 16, 2011.
  1. Fine, normal wear after that time, good for another 50k miles
    15 vote(s)
    55.6%
  2. Worn, Going to need replacement soon
    11 vote(s)
    40.7%
  3. Toast, get those replaced ASAP
    1 vote(s)
    3.7%
  4. Other - Please explain
    0 vote(s)
    0.0%
  1. Feb 15, 2011 at 11:20 PM
    jdtemple
    jdtemple [OP] Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Having some front end issues, and starting to wonder. I have taken my truck to the dealer, only to not have my issue resolved. When they finally did resolve my issue, the repair caused a few new issues.
    Adding A poll, but please add any input.
    so, with out further delay, Here are photos of bushings in questions with 3 years 4 months on the road, or 48,800 miles. I have a 2 inch spacer/leveling lift on the front.
  2. Feb 16, 2011 at 8:40 AM
    jdtemple
    Bay Area CA
    how long has your truck been on the road, and how many miles?
  3. Feb 16, 2011 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They look fine. If they were bad, you would see cracking.
  4. Feb 16, 2011 at 8:47 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Regarding the wandering, loosen the LCA nuts and see if you can turn the alignment cams. There's a chance your cams are seized inside the LCAs. They're not lubricated from the factory.
    What did the dealer do to fix the issue, and what new issues were introduced after that?
  5. Feb 16, 2011 at 8:50 AM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    x2. its all good
  6. Feb 16, 2011 at 11:29 AM
    jdtemple
    Bay Area CA
    I had the basic pop/click sound coming from the front end when entering and exiting driveways. I finally figured out that the alignment cams were sliding back and forth. I crawled under the truck with a torque wrench and made sure everything was tightened to specs.
    So I take it to the dealer (2nd Trip for the same issue, they tried to blame other things) with picture proof that stuff is moving. They tell me that the lower a-arm bolts are loose, and that they put it on the alignment rack and inspected it, and they claimed everything was fine, just loose bolts.
    So I pick up the truck, the main sound I was hearing is gone, but now I have a wheel rub in reverse when backing up.
    Here is a pic of the original issue, and that is the bolt is sliding left-right, and the left side of the tab has slowly worn and bent because of it.
    Here is a picture of the fix, and now the tire rub in reverse.
    I am just a little bit pissed off at this point, and will be taking more steps today.
  7. Feb 16, 2011 at 12:41 PM
    mjp2
    NJ
    Looks like they ground off the tab entirely.
    jdtemple, there's no way that will hold an alignment. The alignment cam has nothing to hold it in place.
    I'd be pissed too. You're looking at some grinding and welding to fix this properly.
  8. Feb 16, 2011 at 12:47 PM
    jdtemple
    Bay Area CA
    Actually they just tightened the cam on top of the tab and almost flattened it. I will post a pic of the view from the bottom. So eventually the problem will re-surface and cost more to fix. I have documents and photos of the entire issue.
    At the dealership now, truck is on the rack. This is the last chance to get it right.
  9. Feb 16, 2011 at 12:51 PM
    mjp2
    NJ
    If all else fails and you know a good welder, buy the "FJ Cruiser & 05+ Tacoma Lower Control Arm Cam Tab Gussets" from Total Chaos and have them installed.
    http://www.chaosfab.com/toyaccess_05taco.html
    It's a permanent solution. The results will be similar to a custom deal I had made for my truck.
    Before, showing the mashed tab:
    After, with the LCA mounts reinforced:
    Keep us posted!
  10. Feb 16, 2011 at 1:34 PM
    jdtemple
    Bay Area CA
    That is nice, Excelent solution from TC. Price is not bad either.
  11. Feb 16, 2011 at 1:46 PM
    mjp2
    NJ
    The TC solution will be a little different than my setup but it's close enough to get the idea. And yeah, you really can't beat the price!
  12. Feb 16, 2011 at 4:58 PM
    jdtemple
    Bay Area CA
    Just a quick update;
    They fixed there major screw up, and went above and beyond. They tightened up all the tabs, and so far the alignment is right on the money. I will post pics later.
  13. Feb 17, 2011 at 1:07 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    a solid axle swap would def. fix your problems!
    is it still holding alignment tho? it seems as tho the tabs were almost flat....did they do anything to remedy that? i would think that they would just wear down after awhile
  14. Apr 7, 2011 at 8:19 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
