Rats,I spun one of the sidestep anchors when installing my sidesteps.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jlewis50, Jun 12, 2016.
  1. Jun 12, 2016 at 5:49 PM
    Jlewis50
    Jlewis50 [OP] New Member
    when installing my sidesteps on my new 2016 Tacoma, I got too aggressive with my impact and spun one of the anchors. All of the 5 other anchors are nice and tight with no issues.
    Any ideas how to remove the one bolt that the anchor spins with? Will a well nut work in place of the factory anchor if I get the anchor removed?
    I didn't attempt to loosen the tight bolt yet and see if the anchor insert will fall out.
  2. Jun 12, 2016 at 5:55 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Can you post a picture of the area you are talking about?
    Did you strip one of the welded nuts that are on the frame?
  3. Jun 12, 2016 at 6:02 PM
    Jlewis50
    Yeah the welded nut. The bolt isn't cross threaded. When I over torqued it the nut insert spun in its mount.
  4. Jun 12, 2016 at 6:08 PM
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    JB weld and let it dry for 24 hours. If that doesn't work, the best way will be to have it spot welded.
  5. Jun 12, 2016 at 6:08 PM
    aero90
    The nut insert spun on its mount?? The only ones I have seen are welded to the frame. Any pictures?? Maybe it is a different spot.
    It is hard to say what to do without a visual.
    If it is one of the nuts that are inside the frame members and you can't access that position you are going to need to do a modification to that hole. I hope not...
  6. Jun 12, 2016 at 6:09 PM
    aero90
    If you can access it easily enough to JB weld it, please don't cheap out on it. Definitely go with the spot welded option.
  7. Jun 12, 2016 at 6:11 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Get some pics, we can prob help you figure it out :)
  8. Jun 12, 2016 at 6:12 PM
    Jlewis50
    This anchor point is on the BODY. It is one of the 6 anchor points that support side steps.
