Rattle after rear spring TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hophornbeam, Mar 12, 2012.
  1. Mar 12, 2012 at 6:49 PM
    Hophornbeam
    Hophornbeam [OP] Member
    Trevor
    Adamant, VT, USA
    2011 4x4 Double Cab SR5 longbed
    Had the rear spring TSB done about a week ago- pleased with the improvement.
    I am noticing a sound that I never heard before- a rattle/ clunk that sounds like it is below and well in back of the back seat, but not all the way at the back of the truck.
    It occurs on medium bumps, especially if there is a sharpness to the bumps (like washboard unpaved road), not on small bumps and not on large bumps.
    It's a lot like the sound of a receiver hitch clunk from the slight slack between hitch and receiver, except not as far in the back, and there is nothing in my hitch receiver.
    Never heard this before the spring TSB was installed.
    Any suggestions on what to check?
    Thanks!
  2. Mar 16, 2012 at 10:43 AM
    blueburban6
    blueburban6 Well-Known Member
    Nick
    Northern New Jersey
    2011 SR5 Double Cab 4x4
    I know you said its not all the way in the back but I had a similar issue and realized it was my ball mount in the trailer hitch bouncing over bumps. Might not be the same issue but just figured I put that out there.
  3. Mar 16, 2012 at 10:53 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is the spare tire loose in the carrier ?
  4. Mar 16, 2012 at 3:04 PM
    kspeer
    kspeer New Member
    New Mexico
    09 Tacoma TRD
    On mine it was the exhaust pipe. It would move quite easy. As I have driven it its gotten better. Not sure if it applies or if they removed yours. Mine had the clutch tsb
    done on it the same time.
  5. Mar 16, 2012 at 3:07 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Anything in your underseat compartment?
