Rattle/ Clank Sound - Dealership suggested TSB TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spikele, Jun 23, 2010.
  1. Jun 23, 2010 at 9:16 AM
    spikele
    spikele [OP] Well-Known Member
    I have an 07' DC with 42,000+ miles on it. I took the truck into the dealership yesterday and test drove with one of their techs to confirm the issue. Issue confirmed, and I got a call after they hoisted it up in the air, they said that the rear leaf springs were worn. So they did the TSB for it and I picked up the truck. Drove it home, no issues.
    But...when I drove it to work this morning, I could definitely hear the rattle/ clank sound. It's just not that noticeable as it once was.
    Should I...take it back and make a scene? Or just take it back?
    Anyone have any ideas?
  2. Jun 23, 2010 at 9:27 AM
    Brunes
    Brunes abides.
    Rotorhead
    Why would you ASK if you should go make a scene?? They hooked you up with the TSB cause you are already out of warranty...Take it back- talk with them more.
    No need to go high and right because there generosity didn't fix the problem right off the bat...There can be lots of problems that cause rattling....Springs are a good place to start-but I'd guess some more work is needed. Even if it does take more- you got free new springs...so keep working reasonably with them.
  3. Jun 23, 2010 at 9:29 AM
    jamesglynn
    jamesglynn James
    James
    Alabama
    2010 TRD Off Road, Dble Cab, Magnetic Gray
    catch more flies with sugar than with water!
  4. Jun 23, 2010 at 9:29 AM
    spikele
    Oh sorry, forgot to add that I have an extended warranty. So it was covered.
  5. Jun 23, 2010 at 9:29 AM
    jamesglynn
    jamesglynn James
    James
    Alabama
    catch more flies with sugar than vinegar!
    Sorry!
  6. Jun 23, 2010 at 9:31 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If your truck's issue still has a problem then take it back. Be civil and polite, but be firm in your resolve to have it fixed. There is no reason to make a scene. Besides when you provoke others with unnecessary shouting and other rude behavior they are much less likely to help you.
  7. Jun 23, 2010 at 9:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    Actually- I think if you read the TSB it states 3yr/36K warranty...so I'd say you got lucky with a good dealership or you pulled one over on them.
    Either way-Free springs @ 42K miles is a great deal...Keep being civil with them...It'll get you further.
  8. Jun 23, 2010 at 9:35 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Can you describe clunk rattle little more? If sound changed it could be U-joint, center bearing, propeller shaft. All those will have been affected by the TSB since their position would change.
    Take a back and be polite.... :)
    EDIT: When was the last time you greased u-joints, shaft ?
  9. Jun 23, 2010 at 10:49 AM
    spikele
    Greased my u-joints/shafts at 30,000 miles.
    The clank/ rattle is coming from the right rear of the vehicle.
