Rattle/Flutter when decelerating sometimes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by afanofosc, Jul 25, 2022.
  1. Jul 25, 2022 at 1:59 PM
    afanofosc
    afanofosc [OP] New Member
    My 2005 Tacoma PreRunner recently started making a rattle/flutter sound as I decelerate. Seems to stop after driving a few minutes. It is not always present. I've recorded 3 short videos where you can hear the noise.
    It started maybe a month or so after I had the center support bearing replaced to the tune of $1k recently. The old bearing was squeaking loudly at slow speeds. I also occasionally feel a shudder/vibration like I was driving over rough pavement.
    Any thoughts what this sound might be? It's a sort of ratatatatat sound.
  2. Jul 25, 2022 at 2:46 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    You need to go back to the garage that charged you 1K for your center bearing support and kick them in the family jewels for overcharging you so much
  3. Jul 25, 2022 at 2:47 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Can’t really isolate and hear the noise in the video that you are explaining
  4. Jul 25, 2022 at 2:51 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    It is probably an exhaust heat shield loose that they forgot to tighten or was corroded and has failed. Probably related to the work that was done.
  5. Jul 25, 2022 at 5:25 PM
    afanofosc
    In each video it is the "ratatatatatat" sound that is clearly present about 1-2 seconds in. In the 3rd video the "ratatatatat" lasts about 1/2 as long as in the other 2 videos.
  6. Jul 25, 2022 at 5:29 PM
    afanofosc
    I will check but it is not at all clear to me how a loose heat shield would make the virtually identical "ratatatatatatatat" noise that you can hear in all three videos. It doesn't sound like a random rattle that I would imagine a loose heat shield would sound like. Can you point me to a recording online of what a lose heat shield sounds like when it rattles?
