Rattle from engine under acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by neener, Feb 6, 2015.
  1. Feb 6, 2015 at 9:44 AM
    neener
    neener [OP] New Member
    Hi guys/gals,
    I'm helping a friend out with her 99 3.4L tacoma...she was told that the engine needed replacing due to a thrown rod. I told her to not do anything until I looked at it. Checked it out lat night and the car started right up and idled just fine. No CEL, no weird noises...nothing.
    When I gave it throttle, a rattling noise started coming from the block. It didn't seem like it was coming from the heads (valves) and I HIGHLY doubt a rod was thrown (I've heard what that sounds like).
    I'm thinking one of two things and am looking for this great forums feedback:
    1) loose spark plug
    2) loose timing belt (bad tensioner or similar)
    If it the timing belt which is loose and thus resonating or rattling off the timing cover...can I check this without having to take off the PS pump, radiator and AC compressor? Can I pull that top cover portion without touching anything else?
  2. Feb 6, 2015 at 10:10 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    You should make a video and post it so that people can hear what it sounds like.
  3. Feb 6, 2015 at 2:04 PM
    neener
    Can I check timing belt tension without having to fuss with the radiator?
  4. Feb 6, 2015 at 3:43 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  5. Feb 6, 2015 at 7:02 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    If you remove the upper radiator hose from the engine side, you can then get the upper timing belt cover off by removing the 10mm bolts that hold it on.
    Just curious if the motor is leaking any oil? Was it ran low on oil? If you look for posts by my username you'll find where I just swapped on a replacement 3.4L into a 2000 Tacoma. I posted up a video of the engine making a noise. You might want to compare.
    Also run the engine for a 15-20 seconds and then check the oil. See if there are any metal particulates showing on the dip stick.
