Rattle from odometer at 500rpms, Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blars25, Aug 8, 2025.
  1. Aug 8, 2025 at 11:42 AM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
    This rattle occurrs when idling at 500rpms in drive or reverse. I can’t figure it out, it is coming from the odometer, please help. It goes away when accelerating or driving. 2019 Tacoma with 25k miles on it
  2. Aug 8, 2025 at 11:57 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    You are 100% sure it is coming from the odometer? How did you determine this? Or are you saying it is coming from that area of the dash?
    PS: welcome to TW!
    eurowner likes this.
  3. Aug 8, 2025 at 12:02 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Gauge cluster is relatively easy to access if it’s definitely that. The surrounding plastic comes right off with a little tug. There are screws holding the cluster in place, might be worth seeing if they need to be tightened up.
  4. Aug 8, 2025 at 12:09 PM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
    It is coming from that area in the dash, almost sounds like a fan hitting something but it is a mild tick!
  5. Aug 8, 2025 at 12:09 PM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
    500-1000rpms not moving, when I accelerate it goes away completely until the stoplight.
  6. Aug 8, 2025 at 12:13 PM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
    I wish I could upload the video! I am not sure how to if it is possible.
  7. Aug 8, 2025 at 12:23 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This isn't a problem that needs fixing. You drive a truck, not a Lexus. Shift into neutral when sitting at a red light for a long time.
    Phlogiston likes this.
  8. Aug 8, 2025 at 12:26 PM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
  9. Aug 8, 2025 at 12:28 PM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
    It needs fixing, I can let a lot of things go but not this everytime I stop!
  10. Aug 8, 2025 at 12:33 PM
    Buck Henry
    Yeah, I concur that it's a rattle from that area. You're just going to have to start snooping around in there and tighten up what you can.
    BTW, that would drive me crazy too. Good luck brother!
  11. Aug 8, 2025 at 12:38 PM
    Blars25
    Blars25 [OP] Member
    Brendon
    2019 Tacoma Red
    , I need to figure it out quickly!! Haha
  12. Aug 8, 2025 at 5:04 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    At least not happening at speed. You should be able to set the parking brake, put it in gear and then start applying pressure to things until you track it down
    joba27n likes this.
  13. Aug 8, 2025 at 5:48 PM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Snoop around!
    https://youtu.be/lfYY4FcyEl0?si=hVxp0ft38edvLK1b
  14. Aug 8, 2025 at 5:50 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Chew likes this.
  15. Aug 8, 2025 at 6:13 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  16. Aug 8, 2025 at 6:17 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Do you have small kids?
    That is a classic noise where a child dropped a penny in an AC vent. Ask me how I know.
    Chew and RustyGreen like this.
  17. Aug 8, 2025 at 7:50 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    That would drive me nutz too, shouldn't be too tough to isolate though.
  18. Aug 8, 2025 at 8:14 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    how do you know?
  19. Aug 8, 2025 at 8:15 PM
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Pop the hood while it's idling, poke your head around in there and make sure it's not something in the engine bay that's transferring noise through the dash.
  20. Aug 8, 2025 at 9:47 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I agree, this needs fixing!
    Also agree with @Phlogiston on where to start. There was another poster IIRC that found a noise originating from the steering column attachment bolt/stud within the cowl area that was in the same combo meter area.
    Good luck.
