Rattle from the Airbox (K&N Filter)
Discussion in 'Technical Chat' started by Sinister, May 18, 2009.
  1. May 18, 2009 at 7:59 PM
    Sinister
    Sinister [OP] Well-Known Member
    Vegas
    11 Super White TRD Off-Road
    WeatherTech Liners, ICON Stage 3 front and back, ICON UCAs, ICON AAL
    I have noticed since I dropped in a KN on my 09 V6 that there is a rattle/rumbling sound from the airbox. Does anyone else notice this? What is the cause?
  2. May 18, 2009 at 9:56 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    is it the drop in filter or the cold air intake type?
  3. May 18, 2009 at 11:02 PM
    MannyECG
    MannyECG MasterChief
    Tempe, AZ
    06 TRD Sport, 4x4, D-Cab, Long Bed
    K&N Air Intake, BFG A/Ts, N-Fab Nerf Steps, Tailgate Pop N Lock
    Assuming you have a CAI and that you checked for any loose parts, you might want to check that your filter cone is not touching the heat shield hole. If it's not, move it around a bit to see if it does touch the heat shield. Sometimes even the clamp might be close to it and when the truck is running, it might tap the heat shield causing the rattling.
  4. May 19, 2009 at 5:53 AM
    Sinister
    Vegas
    I guess I left out a key component. Its a drop in filter, and I have checked all connections and latches. Everything is secure. I mainly hear it in the morning when I'm pulling out of the garage. Does the KN add a low rumble? I never noticed it in my F150 but that was cone filter and this one is a flat one.
  5. May 19, 2009 at 7:48 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    It will make your intake louder yes. rattling? it shouldnt.
  6. May 19, 2009 at 7:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like its not fitting tight. Have you checked it?
  7. May 19, 2009 at 4:54 PM
    Sinister
    Vegas
    Checked the fit. Its tight. I guess what I am hearing is the intake. Just thought it was strange. Guess there is not alot of sound deadning materail in the firewall. I can live with it, was just curious..
    Thanks for the info.
