Rattle in left front wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sfetty, Jun 19, 2010.
  1. Jun 19, 2010 at 4:38 PM
    sfetty
    sfetty [OP] Member
    WV
    09 Tacoma Dbl Cab 6ft bed
    I have a very noticeable rattle coming from the left front wheel everytime I hit a bump or hole in the road. The rattle quits as soon as I put on the brakes. I have taken my 2009 Tacoma( 20,000 miles on it) to 2 different Toyota dealerships including the one that I bought the truck from (that experience will be another post).
    So far, this is a list of things that both dealerships have done to correct the problem:
    1) Replaced both link assemblies on the front stabilizer bars.
    2) Repaced caliper on right front wheel
    3) Replaced front brake pads on both front wheels
    4) Replaced rotor on right front wheel
    None of these corrective measures have eliminated the rattle. Has anyone else experienced this problem and if so, what was the solution? If it doesn't get corrected, I am either filing with the state "lemon law" officials or trading this "rattle" trap off for a Ford F-150. I hate to do that because I really like my Tacoma, but I am not going to put up with that rattle!
  2. Jun 19, 2010 at 4:51 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2015 RAV4...c'mon lease, end already!
    3 Tacomas so far, waiting impatiently for my 4th
    I was going to suggest you try bending the pad mounting clips, but if they already replaced the front pads I guess that probably won't help.
    Are you able to jack up the left front and hit the side wall with your palm or a rubber mallet to try to see where the rattle is coming from exactly? Maybe try something similar with the wheel off as well.
    You would think one of the dealerships would have done something like this, but apparently they have been unsuccessful. Then again, it's not their truck and maybe they are some of the ones that don't give a crap.
  3. Jun 19, 2010 at 5:39 PM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    if you kick the wheel and it makes the noise. it could be a metal piece that goes over the screw for you axle(4wd). you need to put a pin to keep it from hitting the hub cover. well that's what I did for my truck when it was making a noise. just really depends on where the noise is coming from.
  4. Jun 20, 2010 at 12:02 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Keep taking it to the same dealership util its solved.
  5. Jun 20, 2010 at 12:10 AM
    bullshooter
    bullshooter Active Member
    central illinois
    08' Indigo TRD Sport 4x4
    access tonno
    i have a 2008 and it does exactly what you described, even when applying the brakes to make it stop
  6. Jun 20, 2010 at 7:47 AM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    This is that damn rattle/clinking sound I have. It doesn't happen if you're on the brakes. Now I have noticed as soon as I hit the brakes, they make a "clink" sound. I have not been able to find an answer either :( It sounds like its coming from my left front wheel area.
  7. Jun 20, 2010 at 10:07 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    It may be the steering shaft. Go up in the left side wheel well and move the steering shaft around, it will make a distinct rattle type noise. Is this the noise you are hearing?
  8. Jun 20, 2010 at 7:58 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Helpful link : http://www.toyotanation.com/forum/showthread.php?t=342033
