Rattle in the driver's door....striker maybe?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mac84, Aug 3, 2018.
  1. Aug 3, 2018 at 9:52 AM
    mac84
    mac84 [OP] Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Have developed a door 'rattle' (it sounds a little like a knocking also). It sounds like it's coming from the driver's door but I've resisted taking the door panel off because I've never done it AND it's 19 years old...sure I'll crack something.
    I did notice early in the week that the striker on the door post (U shaped, silver) was loose so I tightened it. Thought that was it but it's back. My question is whether or not an adjustment of this striker might solve it or identify the rattle? Anybody seen this before? Thanks.
  2. Aug 3, 2018 at 11:15 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I wouldn't mess with the striker plate on the jamb if I were you unless the door appears dorked when closed, or unless you can move the door when it's closed.
    The flat locking knob that sticks up from the inner door trim rattles on my truck. Like you, I don't really relish pulling the door panel off, so I'll wait on this one until it, or something else, gives me major headaches or goes completely belly-up...
  3. Aug 3, 2018 at 11:20 AM
    mac84
    Alabama
    I'm sort of with you on this....That certainly would seem to affect the fit of the door.
    Do you mean the one that pulls up (The flat locking knob you mention?)
  4. Aug 3, 2018 at 11:22 AM
    skeezix
    Colorado
    1998 Limited
    That's the one!
  5. Aug 3, 2018 at 11:24 AM
    mac84
    Alabama
    It's driving me NUTS.
  6. Aug 3, 2018 at 11:25 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  7. Aug 3, 2018 at 11:28 AM
    mac84
    Alabama
    I'm going to be out of town for 2 weeks....when I get back I think I'll get my game-face on w/ this project.
  8. Aug 3, 2018 at 2:36 PM
    OneWheelPeel
    Phoenix, AZ
    On the edge of our seats
  9. Aug 3, 2018 at 3:38 PM
    Brokebrute
    Brokebrute Well-Known Member
    Joe
    2004 Tacoma TRD
    Grey wire mod and 2 low mod
    Check the bolt on the back of the door below the latch. On my Tacoma the door cracked around it, it is the lower window track mount bolt. If you close the door a lot with the window down it breaks the door and flops around inside. My 85 Toyota did this also.
  10. Aug 3, 2018 at 3:54 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Does it change depending on the position of the window? If so, could be a loose window frame nut to inner door panel or bad glass run (rubber the window slides up/down inside).
