Rattle in the steering column
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rzimm001, Sep 1, 2009.
  1. Sep 1, 2009 at 11:48 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I just recently came across a problem with my 2008 Tacoma rd. There seems to be a rattle in the steering column when going over small bumps at a mild speed. After reading other posts about it I decided to look under the column just a few minutes ago and see what's up. What I found wasn't at all like what I have been reading. Apparently there is a small locking washer with teeth on the inside edge that fits over the steering shaft right above the break pedal. I found it just rattling loose at the bottom of the shaft. There is a groove in the steering column which this washer locks into and keeps the shaft tight in position. I guess without it the shaft can float in and out of its hole. I couldn't fix it with just my fingers. I'll get some tools under there tomorrow and make sure it clips back in. Anybody else experience this :confused:
  2. Sep 2, 2009 at 4:19 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    Can you post a picture?
  3. Sep 11, 2009 at 4:16 AM
    tacobale
    tacobale Well-Known Member
    I think I had the same problem in my 09. It was making my steering wheel oscillate at speeds 65mph and above. The dealership Mechanic found it. So far, the oscillation hasn't returned.But I haven't driven it much since.This was found last night. There are 2 u-joints and 1 collar on the steering shaft that tighten against the splined steering shaft. Mine had play in it. Now no more play after tightening, and so far no more steering wheel oscillation.
    Everyone with oscillation at highway speeds need to check these connections.
  4. Sep 11, 2009 at 4:22 AM
    dalsmthme
    Ithaca, NY
    I still want to see pictures from the original post. My collar is tight, so it isn't that. I don't have a splined washer or groove for one to go in......
  5. Sep 24, 2009 at 5:10 AM
    Major91
    Major91 Well-Known Member
    Masshole
    2009 TRD OffROAD Barcelona Red
    On Anytime Fog Lights Satoshi Grillcraft Misc LEDS 5100's all around Konig's16". Duratracks, debadged,tinted fronts, custom shifter, flyzeye
    Had my steering column replaced yesterday at the dealership in view of the rattle i was having. Well that fixed the issue as they explained to me that there must have been a bad bearing inside. Anyway i walk to the truck and was about to get in the drivers seat when i noticed that some sloppy mechanic left his grime and dirt all over my seat and arm rest. On top of that it looks like they used a screw driver or something to pop off the cover to the column which now looks like crap! I'm not even sure the truck is driving straight.........good lord.......well......i'm about to call the dealership back to pick this up and give me a ride until the issues are resolved..........my luck! :mad:
  6. Sep 24, 2009 at 5:28 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :( It's bad enough you have to take it back for stupid shi+ like that, then some d-bag can't take the time or does not know how to take the time to do it right. Good luck, keep us posted. :smack:
  7. Sep 24, 2009 at 6:09 AM
    Major91
    Masshole
    Well this morning the dealership washed the inside where i had dirt/oil on the seat and floor......turned out nice. They are ordering the cover for the steering column and will do the allignment at the same time. Also will be washing/vac the entire truck after...........we will see how this goes. BUT this could of been avoided easily with common sense. :smack:
  8. Sep 24, 2009 at 6:37 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I would have never left the dealership without this being resolved.
  9. Sep 24, 2009 at 6:39 AM
    09blacktaco
    09blacktaco Well-Known Member
    The Rockies
    09 DC 4x4 TRD OR
    I once had a Grand Cherokee with some issues, so I took it to the Jeep dealership. After they fixed the problem, they parked it outside with the windows down. Well, It rained for about 2 hours. I mean a torrential downpour. When i got there to pick it up, i took one look inside and headed back inside the dealership. The service manager looked at me and asked me what the problem was. I just told him to come see for himself.
    They had to replace almost every interior part in that jeep. Heated leather seats, gauge cluster, radio, speakers, AC controls, steering wheel controls, carpet, etc.
    I had a brand new G Cherokee to drive around for almost a month while they replaced everything for free.
    Dealerships aren't the best place to take your car, thats for sure!
  10. Sep 24, 2009 at 6:41 AM
    Major91
    Masshole
    I hear ya! But.....the allignment is off but not that bad. Part needed to be ordered anyway so there was'nt much for me to have done until that steering wheel cover comes in.........Its just my luck! :(
  11. Sep 24, 2009 at 6:44 AM
    Major91
    Masshole
    Your so right on with that! But.....since this is warranty work i really had no choice............
