Rattle inside Cab???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aubi1414, Mar 5, 2013.
  1. Mar 5, 2013 at 12:28 PM
    aubi1414
    aubi1414 [OP] War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    I have a slight vibration when braking causing something to rattle inside my cab that sounds like it is coming from my glove box(its not the stuff in it) when I brake. Has anyone else experienced this? What might I check to fix this? Its not the speakers I know this much.
  2. Mar 5, 2013 at 12:43 PM
    dsjones5
    dsjones5 Well-Known Member
    DSJ
    Georgia
    2011 MG DC Taco
    Seat covers, weather tech digi fit, bug deflector, plasti dip wheels, magnaflow muffler, and many more to come!.. as soon as i get money. Ill probably go broke typing this...
    It may be the glove box itself. I have a 2011 Taco and my glove box door rattles from 1000 to 1500 rpm upon take off. Also my front passenger speaker has some rattle to it. Just put some door trim foam around the glove box and that may help. Otherwise its probably behind the dash. :confused:
    But our trucks are quirky so who knows.
  3. Mar 5, 2013 at 12:45 PM
    bassinman
    bassinman Well-Known Member
    Gilbert Arizona
    11 Prerunner SR5
    Tint, WeatherTech mats, Differential Breather Mod, Fogs on anytime mod, Seatbelt chime disabled, glove box led's, Rear spring TSB
    It's really difficult to identify where rattles come from. I thought I had a glove box rattle and it turned out to be the passenger seat belt buckle rattling against the B-pillar. I fixed it with velcro on the back of the buckle and on the pillar. Good luck with your noise.
  4. Mar 5, 2013 at 12:45 PM
    aubi1414
    Justin
    Pensacola, FL
    Glad to know someone else has the same issues....It irritates the piss out of me sounds like the damn dash is falling off!! Ill trim it w/ foam and see what that does. Thanks and I sure as hell hope it isnt behind the dash. :mad:
  5. Mar 5, 2013 at 12:46 PM
    aubi1414
    Justin
    Pensacola, FL
    Thanks if the glove box trim foam doesn't fix it this will be my next attempt at quieting whatever it is.....
