Rattle noise
Discussion in '4th Gen. Tacomas (2024+)' started by Wahhabm, Feb 18, 2025.
  1. Feb 18, 2025 at 12:30 PM
    Wahhabm
    Wahhabm [OP] Well-Known Member
    Monther
    I see many posts related to noise in our Tacoma but nothing related to what I am experiencing, loud fast noise at around 10 to 20 mph. It sounds like in the windshield area as if something was bouncing against it. Any ideas?
  2. Feb 18, 2025 at 12:40 PM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    something is actually bouncing against it... how about you and your good buddy go drive it and you take a video of it while you point to exactly where the noise is coming from. then maybe we can help. if you take it to the dealership it would be best to do that exact same thing with a tech so you know they heard it.
    Wahhabm[OP] likes this.
  3. Feb 21, 2025 at 6:58 PM
    Wahhabm
    Monther
    TurboDA6 likes this.
  4. Feb 23, 2025 at 4:33 PM
    Brenn1017
    Brenn1017 Well-Known Member
    2nd gen access cab
    yup i heard it, i got that too. no idea what it is
  5. Feb 23, 2025 at 4:38 PM
    Taco2GR86
    Taco2GR86 Well-Known Member
    2021 TRD Pro 6MT [sold]; 2024 TRD OR 6MT
    Try taking your sunglasses out of the sunglasses holder
    wilcam47 likes this.
  6. Feb 24, 2025 at 7:35 PM
    Wahhabm
    Monther
    I don't have sunglasses there. It is empty.
  7. Feb 25, 2025 at 5:23 AM
    gmtech
    Stock AF
    where was your buddy at ? your supposed to point to where the noise is coming from.... a video online of a noise is terrible for diag. the person watching the video cannot tell if the noise is coming from behind/in front/outside/uptop.. because we are not in the truck with you.
  8. Feb 25, 2025 at 8:20 AM
    Wahhabm
    Monther
    I video tapped myself. The noise appears to be coming from the lower windshield area, but really hard to pin point because if I could tell exactly, I would put my hand to see what is vibrating. Hopefully someone else can figure it out.
  9. Feb 25, 2025 at 8:41 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I'll make a few uneducated guesses. Neddle bearing? Something in the steering? Heat sheild? Which sounds more likely than the first two. What's under the hood on that side of the truck? Hibernating wasp? I got a wasp in my truck I thought it flew back out but last time it warmed up the wasp was back and it climbed down into the window track not to be seen again. Probably not a hibernating wasp.
    gmtech likes this.
  10. Mar 7, 2025 at 8:41 PM
    Brenn1017
    2nd gen access cab
    i have it to, i noticed it today when i was in reverse.
    Wahhabm[QUOTED][OP] likes this.
  11. Mar 7, 2025 at 9:49 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Is your driver window down a couple inches?
  12. Mar 7, 2025 at 10:45 PM
    Wahhabm
    Monther
    No, fully up
  13. Mar 8, 2025 at 5:09 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
  14. Mar 8, 2025 at 5:19 AM
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    this might sound dumb, but if it's an interior rattle, i've found that the brute force method of giving a good thump to random spots in the culprit area can help you locate where its coming from (if you get any rattling feedback), and also sometimes just stop it.
    and @Taco2GR86, i've also fallen victim to the sunglasses rattle :rofl:
  15. Mar 8, 2025 at 5:49 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Sounds almost metallic…maybe try checking those ditch lights or their brackets touching something under the hood?
  16. Mar 8, 2025 at 5:56 AM
    mthopton
    mthopton Well-Known Member
    ‘03 TRD Prerunner, ‘16 TRD DCSB 4x4 - gone, 24 TRD OffRoad
    That def sounds like a heat shield under the truck.
  17. Mar 8, 2025 at 6:51 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    This was my first thought. But then if others w/o puddle light installs hear the same thing, maybe not.
    Assuming your work checked out clear, just roll it in to the dealer and let a certified master technician shake it down. The source of a rattle that obvious should not be difficult for them to locate and fix.
  18. Mar 8, 2025 at 7:47 AM
    Wahhabm
    Monther
    The noise was there before I put the ditch lights and at the time I installed I made sure there was enough clearance because I bought a set from eBay that didn't and I had to return it. I am not sure what shields there are but I also replaced the cheapo engine guards I added the good skid guards and again the noise was there before I added those. So I am not sure what shields other than catalytic converter Shields...
  19. Mar 8, 2025 at 7:59 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I’m on my 3rd Tacoma, they’ve all made weird noises. It gives them character..
  20. Mar 8, 2025 at 8:11 AM
    SandiaMan
    SandiaMan Active Member
    Kelly
    2025 Bronze Tacoma Off-road Premium
    Is it speed related or RPM related?
