Rattle noise
Discussion in '4th Gen. Tacomas (2024+)' started by Wahhabm, Feb 18, 2025.
  1. Mar 8, 2025 at 8:25 AM
    Wahhabm
    Wahhabm [OP] Well-Known Member
    Monther
    I think speed related because revving the engine at idle doesn't cause it.
  2. Mar 8, 2025 at 9:34 AM
    Brenn1017
    Brenn1017 Well-Known Member
    2nd gen access cab
    i only notice mine at low speeds. similar to your video
  3. Mar 8, 2025 at 11:48 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I’m guessing u are missing a piece of foam between dash and windshield area … Toyota being cheap on stuff .,, 40k truck my butt lol
  4. Apr 3, 2025 at 9:47 PM
    BrutusMaximus
    BrutusMaximus Member
    Austin, Tx
    2025 TRD Sport
    I’m not sure if it’s the same thing, but I would get an annoying buzzing bass noise at lower rpms. I bought a Carista OBD2 reader and turned off the Engine Sound Enhancement (ESE) and Active Noise Cancelling (ANC), and the sound has gone away. I think it was the ANC, as I first de-activated the ESE and the sound remained. Seems like it gets stuck in a weird state in certain low RPM scenarios and makes the buzzing noise
  5. Apr 4, 2025 at 4:52 AM
    PARTTAZZ
    PARTTAZZ New Member
    28 Commerce Park Rd
    All stock
    Try to hold the brake in drive and slowly increase the RPM's. If you hear it, it could be a heat shield on the exhaust, or a loose catalytic converter inside the cat. body. Try hitting the exhaust with your hand near the cat's and listen. I have also seen an A/C line or something attached to the firewall vibrating. Good luck, I'm chasing marbles in my dash.
