rattle on passenger side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, Jan 24, 2009.
  1. Jan 24, 2009 at 2:41 PM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    I have a rattle behind the airbag panel on the passenger side, it sounds like it is anyways, its worse when cold... anyone know how to remove this panel, its the one below the top dash but above the glovebox...if i tap it with my hand i can hear the rattle....
    thanks
  2. Jan 24, 2009 at 2:44 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    you can just pull out the glove box but remove the hydraulic thing first. Then its just one bolt where the cover latches on.
  3. Jan 24, 2009 at 2:44 PM
    FlawedXJ
    Paul
    NorAla
    let me know if you need pics. I'll go take some if you do.
  4. Jan 24, 2009 at 2:46 PM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    hey thanks for the fast reply, pics would be great!! mines an 06 btw.
    thanks
  5. Jan 24, 2009 at 2:47 PM
    FlawedXJ
    Paul
    NorAla
    word. give me 5 minutes.
  6. Jan 24, 2009 at 3:00 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    It's been more than 5 minutes.... :laugh:
  7. Jan 24, 2009 at 3:04 PM
    FlawedXJ
    Paul
    NorAla
    Heres what the glove box looks like opened.
    Theres a hydraulic on the right side. Your going to want to slide your hand to the left of it and push right, with a little force applied more so at the top it will pop out like so ( look at above picture, i kinda circled where it needs to pop out.)
    once you have done this its time to pop out the glove box. Here are the tabs holding it in at the bottom:
    Now you can just pull towards you and it will pop out but i usually hit on it with the palm of my hand while its open and it will pop out.
    Now to remove the part to access all the goodies. There is a 10 mm screw holding the top cover in. Here it is:
    Its right behind where the glove box door latches on. Remove that and pull from the back of that plastic piece downward and it will swing down and out.
    Now your left with this (sorry for the quality):
    Now dig around and find out that noise.
  8. Jan 24, 2009 at 3:06 PM
    FlawedXJ
    Paul
    NorAla
    I had to go get tools, take dash apart, take pictures, put circles and stuff in on paint. Give me a break man! If someone could tell me exactly what it is that wiggles, I'd be glad to fix it and finish this and maybe make it a sticky?
  9. Jan 24, 2009 at 3:17 PM
    FlawedXJ
    Paul
    NorAla
    anybody?
  10. Jan 24, 2009 at 3:28 PM
    CRFan1
    CRFan1 Well-Known Member
    Northwest Indiana
    Tacoma Pre-Runner
    DNX5120, Audsion AMp, Hertz Speakers
    I have this exact problem on my brand new 08.....if i hit the front of the passenger dash it rattles (the same part you mention). I have found that if i press down on the top of the dash up by the windshield and than hit the front, no more rattle. I am gonna have to jam some foam in there or something....if it can be fixed at all. Kind of ticks me off really :mad:
  11. Jan 24, 2009 at 3:32 PM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    lol.... just playin' with ya... :D
  12. Jan 24, 2009 at 3:40 PM
    FlawedXJ
    Paul
    NorAla
    yeah i know
  13. Jan 24, 2009 at 4:56 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I think this should be a sticky or a mod and tutorial/
  14. Jan 24, 2009 at 4:58 PM
    FlawedXJ
    Paul
    NorAla
    agreed!
  15. Jan 24, 2009 at 5:01 PM
    Lentsnh
    the sound is like right behind the dash where the airbag kind of is. I cleaned out my cabin air filter and everything and it still makes that annoying rattle.
  16. Jan 24, 2009 at 5:02 PM
    FlawedXJ
    Paul
    NorAla
    while i was in there i rearranged the monster wiring harness and rapped their contact points in foam tape. Haven't driven yet though.
  17. Jan 24, 2009 at 5:05 PM
    Lentsnh
    oh ok once its my truck ill check for EVERYTHING, or when my folks arent home ha
  18. Jan 24, 2009 at 5:28 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Its amazing how little holds these interiors together!
  19. Oct 4, 2010 at 9:06 PM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    I had the same problem. I read it is most likely a broken plastic dash clip. I shoved a 1 or 2 inch piece of rubber tubing on the side of the dash and one between the dash and te window where the rattling was coming from. Problem solved and u can hardly notice it
  20. Oct 4, 2010 at 11:38 PM
    theseuspower
    theseuspower Member
    none
    there is a key hole for air bag off. that is rattle comes from. next time you get rattle noise, put your middle finger into the hole and press a bit. rattle stops. try it.
