Rattle on startup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jaynoble113, Oct 5, 2023.
  1. Jun 9, 2024 at 6:24 PM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    VVT-i
  2. Jun 10, 2024 at 3:38 AM
    Jaynoble113
    Jaynoble113 [OP] Member
    I had both changed before the motor replacement did not fix the issue
    bgavin likes this.
  3. Jun 11, 2024 at 3:00 PM
    Rwdoffroader
    Rwdoffroader New Member
    2017 SR access cab 2.7L
    I have a few more questions since I’m in the same boat and I’m really hoping I don’t have to replace the motor.
    I see you replaced the VVT gears so does that mean it’s not the valve train or stuck lifters like the other user suggested?
    Did it make that noise nearly every time you started it? And was it only ever while starting, or did it happen while driving?
    also was there any other symptoms going on? Or them at noise was all it did
  4. Jun 12, 2024 at 5:31 PM
    Jaynoble113
    The sound was the vvt gears my oil was draining and the rattle was because I had no oil to "UNLOCK" them the mechanic said the man hours to hunt down the cause of the oil draining out of the front plate would come close to the used motor and they may still need to replace the motor when all was said and doneso i went with a motor. Oddly enough it only made the sould when above 50 degrees so all winter it was fine. Good luck.
  5. Jun 13, 2024 at 5:10 AM
    bgavin
    Orangevale, CA
  6. Jun 29, 2024 at 7:05 PM
    maxhirsh
    maxhirsh New Member
    max
    2017 SR5 2.7L
    I'm also having this exact same problem. Same rattle for 15 seconds when starting in the morning on my 2017 2.7L, did you get yours looked at yet? Hoping I don't have to replace motor either.
  7. Oct 22, 2024 at 2:35 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Anyone have an answer to this issue. My truck has started this randomly on cold start
  8. Jan 17, 2025 at 7:03 AM
    AZ Pool Guy
    AZ Pool Guy Member
    Did they change the tensioner when they did the gears? I've got the same exact noise on a '16. I was sure it was the gears and was going to swap them and the tensioner. I have also seen where the top chain guide (https://autoparts.toyota.com/products/product/guide-chain-damper-1356675020) between the gears breaks and lets the chain rattle. I'm curious if this was checked when you got your gears changed.
  9. Feb 26, 2025 at 4:15 AM
    Lsat0902
    Lsat0902 New Member
    2021 Gray Sr5 2.7
    What did you end up doing? I have the same noise and I don’t know if I need to replace the engine or the gears
