Rattle only over 63MPH, need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Jun 7, 2019.
  1. Jun 7, 2019 at 11:12 AM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I need some other ideas to check for this rattle. It only starts just over 60mph, right around 62 to 63. Then it sounds like a rock Is in my tire tread but I have looked at all 4 tires and they are all clean. I also checked the skid plate bolts and all heat shields. All are tight and have no rocks stuck when I smack on them. I have no clue what else to check and I can only recreate the sound on the highway. Ideas???
  2. Jun 7, 2019 at 11:25 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    If you have hammer on wheel weights they can tink on the wheel at certain speeds, check those. Remove catalytic converter heat shields all they do is collect rocks.
  3. Jun 7, 2019 at 11:26 AM
    757yotas
    Virginia
    2007 TRD Sport
    I'll check into the weights
  4. Jun 7, 2019 at 1:03 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Mine used to start at 30 and get obnoxious at 65, they were the ones on the rear lip. Seen it happen on ravs and corollas too
  5. Jun 7, 2019 at 1:33 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    If you have the little flaps bolted to the inside front fender wells... check those. If they get a little loose they will make a nice rattle.
    Just a thought.
    Cheers, Jeff
    757yotas[OP] likes this.
  6. Jun 7, 2019 at 1:45 PM
    757yotas
    Virginia
    2007 TRD Sport
    Another good idea:thumbsup:
