Rattle sound when a/c on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, Jul 2, 2017.
  1. Jul 2, 2017 at 1:17 PM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I'm noticing a strange rattle outside the truck when I'm running my a/c. Any ideas or is that normal? Truck is running fine and a/c is working.
    stuckprerunner and ChadsPride like this.
  2. Jul 2, 2017 at 2:45 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Compressor or bearing?
  3. Jul 2, 2017 at 2:59 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Can you hear the noise inside the truck? Where exactly outside the truck does it sounds like it's coming from?
    The front of the engine is most likely a bearing in the compressor or the compressor clutch like @TegoTaco suggested. If it's coming from the passenger side near the windshield then it's probably the blower fan. Pull the cowling off and stick a shop vac down the fresh air opening and suck out everything you can. Then pull the glovebox and check your cabin filter. If it's missing, for some reason, a twig or leaf couple be running on the fan like a card on the spokes of a kid's bike. If the filter is clogged bad enough, it could have sucked in and be doing the samething.
  4. Jul 2, 2017 at 5:06 PM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Can only really hear it outside. Pretty sure a/c related since it will only make the noise when I turn on the a/c, goes away when I turn off. I'll check out the compressor. Thanks
    ChadsPride likes this.
  5. Jul 2, 2017 at 7:06 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    Pop the hood and start looking around at everything that's connected to the serp belt.
    If you have an infrared thermometer pointing it at all the bearings and looking for one that's running hotter than the others will sometimes reveal a problem.
  6. Jul 3, 2017 at 6:24 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Literally sounds like something is loose and rattleing around.
  7. Jul 3, 2017 at 7:33 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Bearings can sound like that sometimes, so can the clutch. Maybe some debris in your fan assembly and it is hitting against the firewall.
    You need to narrow the component the sound is coming from. Engine Stethoscopes are available from HF and auto part stores, cheap and helpful at times.
    Or you can use a rubber hose to direct the sound to your ear. I know, sounds strange but it works.
    Either way, please post what you find so this thread can be a resource to someone.
  8. Jul 3, 2017 at 7:37 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Had the same issue but on a Sonoma for 75K miles. It was the load the compressor put on the engine that made something else rattle under the truck. Weird thing was if I pushed the clutch in, it went away. Never did figure it out but the A/C could still freeze ice cream when I finally sold it on after 13 years. [it was a 98]
  9. Jul 3, 2017 at 9:19 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    My A/C is making a kinda humming sound for a lack of a better word . You can hear it in the cab and by the grill up front. You cant really hear it when in drive . But I can really hear it in park . It only dos in when the compressor kicks in. It is cooling fine just making that humming like sound. I took it to a shop and the guy said that he though it could be the compressor but was not sure . So under warranty he changed the compressor with no change to the noise. Not sure what to think at this point. :annoyed: I have a 2011 with the 4.0
    xguntherc and ChadsPride like this.
  10. May 11, 2018 at 1:32 AM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Ok, I am having a similar issue after a bad oil leak/cleaning the engine bay, likely ruined the seal. A/C blows cold (42!) and the rattle sound happens when the engine is hot and/or when the a/c clutch is engaged. Essentially when there's a tad bit of extra load on the belt. Can induce with power steering as well. Engine runs fine, then under a/c load, rattle is constant. Load stops, so does rattle. I have it isolated to the clutch assembly area with a mechanics stethoscope. The sound is coming from there. Pulled the belt, wiggled all the pulleys, everything feels fine, so ...another finger pointing at the a/c clutch assembly.
    So here's the rub. I KNOW its the bearing, but you can only get the clutch assembly. Has anyone replaced JUST the bearing on a 4.0L and what's the part#??
    Had a local Toyota only garage look at it, and they only replace the whole compressor and clutch. This is like a $30 part max, never imagined it'd be this elusive.
    stuckprerunner, Nv90 and tesilential like this.
  11. Aug 18, 2021 at 9:05 PM
    Nv90
    Nv90 Member
    Nigel
    2008 Tacoma Double Cab V6
    Same indicators as kasnerd, very inconsistent tick coming from lower passenger side of the engine bay. Only occurs with the ac on, id like to assume ac clutch since it isn't constant. Going to stethoscope the area this weekend.
  12. Aug 19, 2021 at 1:13 AM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    Belt tensioner was bad, so was the clutch. Replaced the idler pulleys at the same time and a new belt. All good.
    Nv90[QUOTED] and wmgeorge like this.
  13. Sep 15, 2021 at 8:18 PM
    Nv90
    Nv90 Member
    Nigel
    Still haven't got around to it, but ill definitely keep that in mind as I'm diagnosing, thanks for the info.
