Rattle underneath
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Honus2b, Jul 31, 2017.
  1. Jul 31, 2017 at 1:53 PM
    Honus2b
    Honus2b [OP] New Member
    E-Rock
    Petoskey, MI
    06 Tacoma 4x4 DC SB
    Hey guys. 2006 Tacoma with 56,000 mi. And I'm getting a rattle underneath that's annoying as hell. Almost sounds like a heat shield rattling but I checked and that's not it. If I'm stopped with my foot on the brake it's really noticeable but if I shift into neutral it goes away. Any ideas what this might be? It's intermittent and isn't constant. Thanks for any suggestions.
  2. Jul 31, 2017 at 3:11 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
    Don't know, but I have the same rattle on my '13. Never have been able to figure it out
  3. Jul 31, 2017 at 5:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    Could be the honeycomb rattling around inside the catalytic convertor. Have your buddy hold the brake and put it in drive while you crawl underneath. Set the ebrake, block the wheels, and make sure it's a buddy that you can trust with your life. If it's not obvious at that point, you need a mechanic's stethoscope.
  4. Jul 31, 2017 at 6:25 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    I had pebbles in my 2nd cat heat shield right under the drivers seat, so i just removed it and all better.
