Rattle upon acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nad, Jul 27, 2009.
  1. Jul 27, 2009 at 7:27 AM
    nad
    nad [OP] mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I seem to have a rattle on my 05 tacoma access cab while accelerating. It is a 6 speed manual and if I dont give it a lot of gas it seems to have a metal on metal rattle. This only happens when I accelerate slow, If I give it lots of gas I cant hear it, this could be because it is being drowned out by the sound of the motor and exhaust though. It sounds to me like there is a lot of pressure going through the exhaust causing it to shake and rattle onto a near by metal plate.
    Has anyone else heard of this problem?
  2. Jul 27, 2009 at 7:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    have you checked around in the engine bay, or along the exhaust for any signes of rubbing, or loose parts?
  3. Jul 27, 2009 at 7:41 AM
    nad
    Jordan
    Canada
    yeah I got under the truck and felt around, couldn't feel anything that was loose and any metal shields seem to be out of the way, I am not positive on this though
  4. Jul 27, 2009 at 7:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe take a rubber hammer, and tap some things under the truck to see if you can reproduce the noise....
  5. Jul 27, 2009 at 7:50 AM
    nad
    Jordan
    Canada
    good idea I will give that a go
  6. Dec 10, 2009 at 6:57 PM
    eyball
    eyball Well-Known Member
    Dudley, MA
    20 Double cab TRD Sport Voodoo Blue
    Did you figure out what the rattle was? I have a rattle at about maybe 2500 rpm or so. It sounds like a heat shield rattle would sound like but the entire exhaust and heat shields look ok. Is there a heat shield on these trucks thats known for rattle/vibration problems?
  7. Dec 10, 2009 at 7:28 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like a heat shield is still suspect , another thing is because of the extreme heat developed inside your CATALYTIC its common to have a heat shield inside a heat shield & maybe a broken tack weld or rivet . bolt.etc; Also check your whole exhaust again from the exhaust flange to the tail pipe , especially where exhaust tubing goes into & comes out of the muffler , Do you have a stock front skid plate ?? Those things sound like your trucks coming apart when they get loose & start vibrating, I dunno, just thinking of places it could be.......:cool:
  8. Dec 10, 2009 at 8:13 PM
    eyball
    Dudley, MA
    Thanks I think I will check the exhaust some more. It does
    sound like it's coming from around the cat but nothing is loose.
    I do have the skid plate but it's tight since it's been off and
    on a lot lately replacing idler pulleys.
  9. Dec 10, 2009 at 8:59 PM
    bdwsrjoe
    bdwsrjoe Well-Known Member
    Joe
    Rio Hondo, TX
    08 Tacoma Double Cab TRD Offroad 4X4
    K&N Cold Air Intake, Magnaflow Catback Exhaust, 3" ToyTec Lift Kit, JVC InDash DVD Player with Backup Camera, 2 10" JL Audio Subs, 8K HID Headlights, 8K HID Foglights, N-Fab Nerf Steps, In-Channel Ventvisors, springfield xd40v10, mossberg 500 12ga.
    Do you have a cai?
  10. Dec 11, 2009 at 3:35 AM
    eyball
    Dudley, MA
    I do have a K&N high flow intake with a cone type filter but it's tight & secure.
  11. Jun 16, 2012 at 9:09 AM
    Kirvine07
    Kirvine07 Member
    Kyle
    VA
    08 4x4 Access Cab
    Wider set tires.
    I am getting this noise too. Had radiator replaced by dealer and then noise started.
    Definitely sounds like heat shield/Loud metal vibration at various rpms and idle.
    Got under while car was running and making noise and couldn't find any loose heat shields that were rattling... I cannot figure it out.
  12. Jun 16, 2012 at 9:42 AM
    eyball
    Dudley, MA
    Mine ended up being one of the clamps on one of the cats and the heat shield on it was rattling because the clamp rusted out. I just put a standard exhaust clamp on it and it's been fine.
