Rattle when truck is turned on???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BuckNuttyTRD, Nov 14, 2014.
  1. Nov 14, 2014 at 5:21 PM
    BuckNuttyTRD
    BuckNuttyTRD [OP] Well-Known Member
    Gresham, OR
    14 TRD DCSB
    So the weather has gotten real cold over the last week. When I go to start the truck after it's been sitting all night or all day at work I hear a rattle coming from the engine compartment. It last for only a few seconds( goes away before I can pop the hood) and it also gets louder when I rev it. ( nothing caught in the fan). Any of you gents have this problem before?
  2. Nov 14, 2014 at 5:23 PM
    BuckNuttyTRD
    Gresham, OR
    14 TRD DCSB
    Should also mention it's a 14 trd off-road with 5k miles and bone stock at the moment.
  3. Nov 14, 2014 at 5:23 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    It wouldn't be your smog pump would it? It starts for a little when starting the truck and shuts off after a few seconds.
  4. Nov 14, 2014 at 5:36 PM
    BuckNuttyTRD
    Gresham, OR
    14 TRD DCSB
    I don't think it would be. I hear the pump when the truck shuts off but never hear anything like this on start up before. Had the truck in for service a week and a half ago...that's the only other thing I could think of other than the cold weather (33 degrees the past week).
  5. Nov 14, 2014 at 5:46 PM
    tacoma956
    tacoma956 Member
    brownsville
    2013 tacoma limited
    I've been having the exact same problem i have a 2013 limited i live in texas its been happening since i took it for its oil change its not due to the weather
  6. Nov 14, 2014 at 6:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Can you post a video? Where does the sound come from, front back left right?
  7. Nov 14, 2014 at 6:15 PM
    BuckNuttyTRD
    Gresham, OR
    14 TRD DCSB
    I will try to get a vid posted tomorrow. I would say the sound is coming from front drivers side.
  8. Nov 14, 2014 at 8:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like the oil filter is draining back to the crankcase and the engine is starting and has to fill the oil filter before the pressure comes up.
    Lots of engines will do this when the filter is upside down and the anti drainback valve isn't working in the filter.
    Get a replacement Toyota filter and just replace the filter.
    My wifes 1998 Sienna Van ( V6 ) did this for a couple of hundred thousand miles and never had any issues.
  9. Nov 14, 2014 at 8:20 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Why does my truck not have one? A smog pump
  10. Nov 15, 2014 at 11:42 AM
    BuckNuttyTRD
    Gresham, OR
    14 TRD DCSB
    So I did a cold start when I woke up and no noise present. Went grocery shopping for a half hour and noise was present.
  11. Nov 15, 2014 at 12:56 PM
    Striper12
    Striper12 Member
    Ron
    Rehoboth, MA
    '06 Tacoma std.
    It might be the heat shield attached to the under side of the body over the exhaust system. Mine did it until I managed to retighten the sheet metal screws holding it in place. Once it gets warm its fine but when cold its slightly loose and vibrates. Ron
  12. Nov 15, 2014 at 1:53 PM
    BuckNuttyTRD
    Gresham, OR
    14 TRD DCSB
    Well I found what it was... Crawled under the truck to check the heat shield, once it all check out good I got a wild hair and checked the fan and fan shroud from the under side for piece of mind because noise got louder at a higher rpm and low and behold the dipshit and the dealership dropped a quart jug between the fan and motor and was rubbing the fan when the motor was on. Not real sure why it would only rub against the fan at a cold start though...
  13. Nov 16, 2014 at 5:27 AM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    You should have snapped a pic and posted it here, sorry it happened but I am glad it was an easy and quick fix.
  14. Nov 16, 2014 at 5:44 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Wow :facepalm:
    Glad it didn't do any damage. :cool:
