Rattle
Discussion in 'Audio & Video' started by pinktaco808, Dec 16, 2010.
  1. Dec 16, 2010 at 5:54 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    how do you guys keep the vents in the corner behind the cab from rattling????
  2. Dec 16, 2010 at 9:35 PM
    pinktaco808
  3. Dec 17, 2010 at 6:39 PM
    pinktaco808
    this
    rear pressure vent
  4. Dec 18, 2010 at 5:27 AM
    mrmumbels
    mrmumbels Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    What vents? What model Tacoma?
  5. Dec 18, 2010 at 7:15 AM
    ToyoDrew
    ToyoDrew Well-Known Member
    Honolulu, HI
    17 Inferno TRD-OR DCSB 4x4
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Not sure if you posted pictures cause I can't see anything...
  6. Dec 18, 2010 at 5:01 PM
    pinktaco808
    for the 2005 tacoma in the corner of each side of the cab
  7. Dec 18, 2010 at 7:36 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Double cab? Access cab? Single cab?
  8. Dec 18, 2010 at 7:50 PM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    cut them out, remove them completely. use high-heat hot glue and silicon to cover the holes with ABS plastic. dynamat over them.
  9. Dec 18, 2010 at 9:08 PM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    5 points shaneckc
  10. Dec 19, 2010 at 6:19 PM
    pinktaco808
    how you gonna cut it out???? damm i had a hard time fitting my hand in there
  11. Dec 19, 2010 at 10:51 PM
    dubbedSinner
    dubbedSinner blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    great stuff to fill in there, works wonders
  12. Dec 20, 2010 at 1:23 AM
    shaneckc
    Shane
    Thousand Oaks, CA
    dremel?
  13. Dec 20, 2010 at 6:55 AM
    pinktaco808
    anyone tried this???? is it better???
  14. Dec 20, 2010 at 11:30 AM
    dubbedSinner
    i did the great stuff and it worked awesome
  15. Dec 20, 2010 at 1:18 PM
    shaneckc
    Shane
    Thousand Oaks, CA
    yep, it cuts a shit ton of noise that comes from those vents. when you turn your AC on or slam your doors, your ears might pop a little, though.
  16. Dec 20, 2010 at 5:38 PM
    zeroendless
    zeroendless Well-Known Member
    Dallas, TX
    Stock
  17. Dec 22, 2010 at 10:00 PM
    pinktaco808
    huh???? not the same
  18. Jun 28, 2011 at 12:28 PM
    pinktaco808
    it for a single cab tacoma man 2010. there is 2, one on each side
