Rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nini, Apr 15, 2018.
  1. Apr 15, 2018 at 6:25 PM
    Nini
    Nini [OP] Member
    2009 Tacoma prerunner v6 sr5
    Hi, new here to this here site. Recently bought my truck and did oil change, oil filter, spark plug replacement, air intake filter. Whenever I accelerate I hear a rattle noise coming from engine. Not sure what it could be but it’s most prevalent when I accelerate. Any help guys?
  2. Apr 15, 2018 at 6:30 PM
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    Is it a pinging type of noise? Wasn't doing that prior to changing plugs?
    Make sure all you plugs tightened snugly and coil packs popped on them securely. I'd start there.
    Check air cleaner box, snugged down too.
  3. Apr 15, 2018 at 6:34 PM
    Nini
    Nini [OP] Member
    It was making the noise before the spark plug replacement. Almost sounds like a fan is hitting something?
  4. Apr 15, 2018 at 6:40 PM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    Might be a loose skid plate or heat shield.
  5. Apr 15, 2018 at 6:44 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    If fan is hitting something loose or broken motor mounts possible .If pinging . Octane gas ? Try higher octane .
  6. Apr 15, 2018 at 6:48 PM
    Nini
    Nini [OP] Member
    Thx guys now I have some likely possibilities I can start investigating
  7. Apr 15, 2018 at 7:00 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Check the intake where it mounts to the fender.
  8. Apr 15, 2018 at 7:12 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Exhaust leak?
  9. Apr 15, 2018 at 7:23 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Does it sound like the noise in my thread?
  10. Apr 15, 2018 at 8:20 PM
    Nini
    Nini [OP] Member
    So I checked everything you guys suggested, no avail. It seems to be coming from the injectors? Maybe I try a injector cleaner or using higher octane fuel?
  11. Apr 15, 2018 at 8:22 PM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Can you post a video of said sound??
  12. Apr 15, 2018 at 8:25 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    try searching Tacoma tick.
