Rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2laner, Dec 5, 2009.
  1. Dec 5, 2009 at 2:54 AM
    2laner
    2laner [OP] Member
    Lewis
    Tennessee
    '95 FWD 5 speed
    Camper cover
    I have a 1995 4WD 2.7L 5 speed with 119.000 miles. There is a rattle/clang noise after starting that only happens when the weather is cold. The lower the outside temperature, the louder the noise. It sounds sort of like heat shields or dampers or the like. I can find no loose parts. At times there is a noise like spark knock/preignition when I press the gas pedal lightly.
    Once last winter the noise was so bad I thought something had really come off the motor. By the time I got the hood up, it had started to go away.
    The motor starts immediately and gives 22 to 24 mpg.
    Any comments appreciated:confused:
  2. Dec 5, 2009 at 5:04 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    I'm pretty sure it's the heat sheild around the exhaust and the tank on my truck. Mine just started doing it. I'm looking at it tomorrow as it's driving me nuts......:goingcrazy:
  3. Dec 5, 2009 at 5:13 AM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    i would have a friend start the truck while you look under the hood.
    are you using the reccomended oil for the temperature range you live in if your oil is too heavy it may be taking more time to reach the head and you may be hearing you valves tapping dry
  4. Dec 5, 2009 at 9:37 AM
    2laner
    2laner [OP] Member
    Lewis
    Tennessee
    '95 FWD 5 speed
    Camper cover
    I run Valvoline 5W 30 changed at 5,000 mile intervals. I'm pretty sure that has been done since it was new. I bought the truck with 48,000 on the odo. The oil level drops and the oil darkens only slightly between changes.
    I still can't get power to my cigarette lighter (Previous post).
    Thanks.
  5. Dec 5, 2009 at 9:54 AM
    j_cyrus
    j_cyrus Well-Known Member
    Atascocita TX
    Where ya at in TN?
  6. Dec 5, 2009 at 11:09 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    It may sound funny, but as things warm up in your cab, they expand, thus the noises will stop......most of the time anyway.:rolleyes: I have the same thing happen to me, drives me crazy! Just turn up your radio, that helps.....:D
  7. Dec 5, 2009 at 1:29 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    What you guys are describing sounds like belt slap, this occurs when its cold i.e; the belt/belts are cold & stiff & are probably warping around the pulleys or tensioner ( depending whether or not you have conventional or serpentine belts) & just like magic it goes away when things warm up, check your belts thoroughly for wear & tension.........:cool:
  8. Dec 5, 2009 at 5:52 PM
    rhodehard09
    tampa, fl
    kudos brother, i neglected to even think about that.
    2 laner...have you changed the timing belt yet? a worn tensioner on it could cause some noise until it warms up. my 85 had plastic guides that were gone and a tensioner that was anything but and when i started it it sounded almost like a snare drum.....but at the same time it barely ran
  9. Dec 6, 2009 at 3:14 AM
    2laner
    2laner [OP] Member
    Lewis
    Tennessee
    '95 FWD 5 speed
    Camper cover
    I live on Signal Mountain 15 miles north of Chattanooga.
  10. Dec 6, 2009 at 5:16 PM
    rhodehard09
    tampa, fl
    what about that rattle?
  11. Dec 6, 2009 at 6:04 PM
    2laner
    2laner [OP] Member
    Lewis
    Tennessee
    '95 FWD 5 speed
    Camper cover
    I haven't done anything about the rattle yet. Maybe tomorrow.
  12. Dec 6, 2009 at 6:11 PM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    I have a rattle in my 04. Can't tell where in the back it's coming from. When you go over rough roads, it sound like the sliding window is rattling but it's not. It sounds more like the noise you get going over 1000 railroad tracks. Can't tell where inside. Maybe it's coming from the side pillar or the bed? Would a spray in bed cause any noises from being stiffer or bad shocks? I also have a bearing noise in the engine area that's just recently started. Can really hear it when the foots of the gas. I read it might be the idler pulley bearing?
  13. Dec 6, 2009 at 7:25 PM
    rhodehard09
    tampa, fl
    could be... take a long screw driver and put the tip on the bracket that holds the pully hold the handle to your ear. (this is like a stethescope)
    it will be real obviose if the bearing is shot
