Rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by old grouch, Feb 4, 2020.
  1. Feb 4, 2020 at 4:32 PM
    old grouch
    old grouch [OP] Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    I just purchased a 2004 DC/SB. When the driver's side window (power) is down there is a serious rattle. Dead quiet when the window is up. Any suggestions?
    GQ7227 likes this.
  2. Feb 4, 2020 at 4:53 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Keep window rolled up
    Or
    Replace the rails
  3. Feb 4, 2020 at 6:47 PM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    If you open the door there should be a bolt on the side of the door. People said you can tighten that up and it might help. I have the same problem. I tried to tighten the bolts and just sheared the head off so I just forgot about it.
    Fuergrissa likes this.
  4. Feb 4, 2020 at 7:59 PM
    Glamisman
    Glamisman Well-Known Member
    the other thing that happens is the spot welds break where the bracket connects to the U glass guide.
    Black DOG Lila likes this.
  5. Feb 5, 2020 at 4:07 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    How would you fix that?
  6. Feb 5, 2020 at 4:15 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    I did the exact thing back when I had my 2000. Thought I’d found the problem and sheared that bolt head right off.
    i chased that noise for months and the whole time my wife was saying “I don’t even hear it”.....and that noise was on my deaf ear side!
    Eventually sold it and bought my 2015
  7. Feb 5, 2020 at 4:59 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    You think they’d make the bolt so you could actually tighten it
  8. Feb 5, 2020 at 7:12 AM
    Glamisman
    I ground down the pulled through spot welds, drilled and used a 1/16" steel pop rivit. I think that the rear glass guide is still avalible from the dealer.
  9. Feb 5, 2020 at 3:51 PM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    I don't have an FSM for the 2004. Will the 1995 version get me inside the door so I can see what is broken/loose?
    GQ7227 likes this.
  10. Feb 5, 2020 at 11:10 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
  11. Feb 6, 2020 at 9:12 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what are the rails?
    is that same as the run channel
  12. Feb 6, 2020 at 9:14 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    one of these bolts?
  13. Feb 6, 2020 at 9:44 AM
    rkilpa
    rkilpa Active Member
    Ron
    2001 Tacoma SR5 Double Cab
    GQ7227[QUOTED] likes this.
  14. Feb 6, 2020 at 9:51 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    should window be all the way up or down when attempting to tighten it?
    i would not have a clue how it ever worked itself loose lol
  15. Feb 6, 2020 at 10:34 AM
    rkilpa
    Ron
    As long as the bolt hasn't come out of the bracket inside the door, it shouldn't matter if the window is up or down when tightening. If it has come out of the bracket, it will be necessary to remove the door panel to line up the hole on the bracket with the bolt so you can re-attach it.
    If the bolt is already snug, do not try to over-tighten it as it could break. If this is the case, you will need to remove the door panel to see what else is loose inside that is causing the rattle.
  16. Feb 19, 2020 at 7:48 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Tightened the bolt & rattle is gone. Thanks all.
