Rattletrap66’s Build and BS (Chevy 63s)
Discussion in '2nd Gen. Builds (2005-2015)' started by Rattletrap66, Oct 6, 2015.
  1. May 8, 2017 at 1:15 PM
    #1961
    Rattletrap66
    Rattletrap66 [OP] (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Whats up poser
    scottalot and ChadsPride like this.
  2. May 8, 2017 at 1:18 PM
    #1962
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Weak af
    ChadsPride likes this.
  3. May 8, 2017 at 1:40 PM
    #1963
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    So how'd those 35s do? :D
    Soul Surfer and ChadsPride like this.
  4. May 8, 2017 at 4:42 PM
    #1964
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Phenomenal! Rubbed a little here and there when fully turned & stuffing but nothing too bad
  5. May 8, 2017 at 4:52 PM
    #1965
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  6. May 8, 2017 at 4:55 PM
    #1966
    ChadsPride
    Sponsored by TacomaWorld.com
    Ssstuuuuhhuuuuufted tho
    NABeast and Rattletrap66[OP] like this.
  7. May 8, 2017 at 5:08 PM
    #1967
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I was going to say ,that dude looks pissed. Hahaha! Yeah I'm on windshield #3 and it's cracked and chipped. I don't even want to have it replaced again, because I know I'll have a chip within a month after. Wtf.
  8. May 8, 2017 at 5:13 PM
    #1968
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I had 2 chips filled with the resin, seems to be holding up great. No cracks.
  9. May 8, 2017 at 5:14 PM
    #1969
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I had one filled before ,shit fell out. Lol. Fly by night service though.
  10. May 8, 2017 at 5:16 PM
    #1970
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Safelite did mine, it's been a couple years at least.
  11. May 8, 2017 at 5:23 PM
    #1971
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    That looks awesome! What psi did you run in the toyo's? How did they do? What did you do with you air intake? I hope you relocated it or something.
  12. May 8, 2017 at 7:11 PM
    #1972
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    16 psi
    Great! Made everything easy lol. Just floated over stuff
    Air intake hose is removed and I have a 90 degree elbow facing the firewall
    NABeast[QUOTED] likes this.
  13. May 8, 2017 at 7:32 PM
    #1973
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Gonna get filthy like that
  14. May 9, 2017 at 5:57 AM
    #1974
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Nope, been running it like that for a year and a half now and no issues with all the mud I've been through
  15. May 9, 2017 at 11:49 AM
    #1975
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Is that the ledge at sheep wallow?
  16. May 9, 2017 at 11:53 AM
    #1976
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yes sir! @gainman and I ended up coming back because @Trident904 pussied out :D
    We explored it more and there were some gnarly hill climbs
  17. May 9, 2017 at 2:41 PM
    #1977
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Pussied out? I wasn't about to destroy my truck. When I have 35's, it's on.
  18. May 9, 2017 at 3:53 PM
    #1978
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    35s won't change anything lol. 33s were more than enough for that place
    Rattletrap66[OP] and ChadsPride like this.
  19. May 9, 2017 at 5:37 PM
    #1979
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Yea pussied out! Like Dom said, 33s would have been fine, plenty of bypasses
  20. May 9, 2017 at 6:00 PM
    #1980
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Destroy now, destroy later. It happens either way :stirthepot:
