Rattling from engine bay (4.0L engine)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJD19, Jan 17, 2025.
  1. Jan 17, 2025 at 11:22 AM
    AJD19
    AJD19 [OP] Member
    Andrew
    2014 Tacoma TRD Sport (6SPD)
    Just wondering if anyone can help give me some peace of mind, I'm driving myself insane over every noise this truck makes. Just today on the way to work, I randomly got a rattling noise from the engine bay. It's only at 2000rpm and only when I give it a decent amount of throttle and then it tapers off pretty quickly, if I slowly accelerate it doesn't make any noise at all. Wondering if maybe it's just a heat shield or something? I would think if it's engine related it wouldn't only happen at 2k rpms and then go away
  2. Jan 17, 2025 at 11:37 AM
    MR5X5
    MR5X5 Well-Known Member
    Heat shields is the place to start. Crawl on under....
  3. Jan 17, 2025 at 11:39 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the air box tube where it enters the fender on the passenger side.
    It can rattle once the “foam bushing” gets old.
    But you’ll notice it rattle on startup when cranking the engine typically.
    BTO, 4WDTrout, Rougarou680 and 2 others like this.
  4. Jan 17, 2025 at 12:27 PM
    AJD19
    AJD19 [OP] Member
    Andrew
    I'm wondering if there's something to this as well. I get a rattle sometimes when it's idling but there's no rhyme or reason to it, it's a different noise to what I originally made the post for. Was thinking maybe my clutch bearing but it doesn't go away when I press the clutch
  5. Jan 17, 2025 at 12:28 PM
    AJD19
    AJD19 [OP] Member
    Andrew
    Figured this is the most common cause, I'll get under there after work and check it out
  6. Jan 18, 2025 at 3:02 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    Yep, been there done that for this, plus heat shield rattles too, good luck
  7. Jan 18, 2025 at 4:46 AM
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    if you figure it out, please share. I'm dealing with the same type noise and rattle that is irregular and sounds like its coming from somewhere behind the steering wheel and dash.
    AJD19[QUOTED][OP] likes this.
  8. Jan 18, 2025 at 7:48 AM
    AJD19
    AJD19 [OP] Member
    Andrew
    Yeah that sounds like exactly what I'm experiencing. Can't really pin point where it's coming from, if I ever figure it out I'll let you know! Wasn't able to duplicate it on the way home yesterday
  9. Jan 18, 2025 at 8:12 AM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    Same
    same here. Drove me & wife nuts till I figured it out.
  10. Jan 18, 2025 at 5:30 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Check the heat shields. I had a similar noise and it ended up being a loose heat shield.
  11. Jan 19, 2025 at 7:06 AM
    spazjensen
    Here
    I have the 2tr 4 cyl. so im not sure how likely it would be the same as you guys with a v6 but at this point im willing to hear or try anything. Can the brake booster cause such a noise? Because that is kind of the area my noise of coming from
  12. Jan 19, 2025 at 7:30 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Have you inspect the motor mounts?
  13. Jan 20, 2025 at 7:55 AM
    AJD19
    AJD19 [OP] Member
    Andrew
    I don't think the brake booster would make that noise, but I could be wrong. I'm not too familiar with the 2.7L layout but I'm assuming you probably have a cat right around that area similar to the V6, try checking the heat shield on that
  14. Jan 20, 2025 at 7:56 AM
    AJD19
    AJD19 [OP] Member
    Andrew
    I have not, maybe a good idea to check
    Kolter45[QUOTED] likes this.
  15. Jan 20, 2025 at 7:57 AM
    wdunnlee
    wdunnlee Well-Known Member
    William
    2010 4x4 base v6
    Have you tried turning up the music :headbang:
    AJD19[OP] likes this.
  16. Jan 20, 2025 at 7:59 AM
    AJD19
    AJD19 [OP] Member
    Andrew
    That's the best solution hahaha
  17. Jan 20, 2025 at 8:26 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Easy culprit is the heat shield, and you're about the age for that to happen. My 10 did it a few years ago.
  18. Jan 20, 2025 at 11:02 AM
    spazjensen
    Here
    no, been to busy on a different project. But I will.
  19. Feb 28, 2025 at 8:04 AM
    AJD19
    AJD19 [OP] Member
    Andrew
    I honestly think it's some spark plug knock. I've still had it happening intermittently and I can't pin-point it. It's been a while since they were changed, so I ordered 6 denso plugs and will update the thread if this solves my issue
  20. Mar 1, 2025 at 7:52 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Just so you know, spark plugs don't knock, engines knock from pre detonation, bad bearings and quite a few other things but I doubt a sparkplug will resolve any of them. Like you said they're old so not a big deal if it doesn't fix the issue.
