Rattling/grinding noise on acceleration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nc_oldhead, Oct 2, 2024.
  1. Oct 2, 2024 at 4:11 PM
    nc_oldhead
    nc_oldhead [OP] Member
    Tyler
    2022 SR5 4x4
    kdizzle likes this.
  2. Oct 2, 2024 at 4:16 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Pings. Sorta normal. Use quality higher octane or get a tune. No other ways to fix it
  3. Oct 2, 2024 at 4:57 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Someone put a zip tie on the drive shaft?
  4. Oct 2, 2024 at 5:16 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    I agree sounds like ping to me. Have you been through a tank of gas since this started? Could be bad gas or something like that.
  5. Oct 2, 2024 at 5:20 PM
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    My truck with 30k on it has done it for 30k lol. Gets slightly better with higher octane. Actually got worse with an OTT tune so I’m all stock now. My 2016 did it as well.
  6. Oct 2, 2024 at 5:22 PM
    Vlady
    Issy, WA
    I'm surprised.
  7. Oct 2, 2024 at 6:42 PM
    ScottThePainter
    I was too. My truck runs good with the stock tune though so I have no real complaints
  8. Oct 2, 2024 at 7:19 PM
    Vlady
    Issy, WA
    Interesting.. I don't have OTT and have been monitoring feedbacks for a while.
  9. Oct 2, 2024 at 7:24 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Pings on acceleration often happen at a certain rpm combined with a certain pressure on the accelerator. Try backing off or pressing harder on the accelerator when this happens.
  10. Oct 2, 2024 at 8:33 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    We run a little more advance than stock (it’s one of the only ways to actually make a little power on this platform)
    If it’s knocked for 30k stock our tune wouldn’t help.
  11. Oct 2, 2024 at 9:03 PM
    Vlady
    Issy, WA
    Is OTT optimized for 87?
  12. Oct 2, 2024 at 9:29 PM
    JustDSM
    Justin
    Ogden, UT
    It’s optimized for 87-91+. Despite everyone throwing around “octane learning” in their marketing, our ignition strategy follows Toyota’s per their patent. If it’s optimized for a specific octane you have hamstrung the knock control strategy by incorrectly configuring the ignition tables. Using the tables as outlined in the patent allows for optimization for a range of fuel grades. You can configure how wide or narrow that range is based on how you configure specific tables. We retain the OE ‘window’.
  13. Oct 3, 2024 at 3:28 PM
    TRD_jay
    TRD_jay Well-Known Member
    2022 Off-Road
    thought i was the only one with that noise lol. i thought it was like a drive shaft or something.
  14. Oct 5, 2024 at 8:11 PM
    kdizzle
    kdizzle Active Member
  15. Oct 5, 2024 at 8:17 PM
    kdizzle
    Try driving with ECT on and see if it helps. I had it on the other day for a bit, and didn't hear it.
  16. Oct 6, 2024 at 12:11 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Sorry OP. The video too short, I do not hear rattling/grinding noise on acceleration. Unless I need hearing exam?:D
    I don't know. Too much "technical mumbo-jumbo." But I was told by my OTT Tuner, the tune does not matter what fuel grades of gasoline, 87-91, I fill in my personal 2023 TRD OffRoad, 6spd manual 4x4, I fill with non-ethanol 89 octane gasoline. Apparenty, the OP Tacoma is automatic.:D
  17. Oct 6, 2024 at 4:03 AM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Same exact problem with my 2021. Tempted to just leave it be but don’t want to damage my engine.
  18. Oct 7, 2024 at 8:16 AM
    kdizzle
    The problem is that it comes and goes depending on the weather & where ur fuel tank level is at. Dealer couldn’t replicate the noise when I took it to them for warranty repairs.
    Plenty of others have had this same problem on their trucks but I haven’t heard of anyone who has gotten it figured out yet.
  19. Oct 7, 2024 at 2:13 PM
    ScottThePainter
    Something I’ve been curious about is whether or not the trucks that have ended up burning valves have had pinging or not.
    Either way it’s my opinion that a majority of these trucks ping to some extent, it’s just that either it’s unnoticed or the drivers aren’t sure what they’re hearing.
  20. Oct 10, 2024 at 7:20 AM
    Angelo1108
    Angelo1108 Member
    Angelo
    2022 Toyota Tacoma SR 2WD/RWD Access Cab Automatic 4 Cylinder 6ft Bed In White
    I’m having concerns regarding my 2022 tacoma that i just purchased yesterday… it came with 67k miles and overall has been a tank. However, just today i started noticing a rattling sound from the front as I accelerate, initially when it’s in the 20-30mph range, and occasionally when I'm accelerating at a higher speed. I heard it could be maybe a wire behind the radio thats tapping, or maybe the dashboard is tapping against the windshield when those initial vibrations kick in when the gears shift as i accelerate. Performance wise the truck is running beautifully as of now. But i always get paranoid over small things like this and im just trying to figure out if anyone had this same issue and if it was just caused by something very stupid and easy to fix. Please someone give me some reassurance and tell me good news Lol.. Also hoping this rattling sound isn’t the start of something mechanical that will kill my truck because i just got it
