Rattling in my engine?
Discussion in 'Performance and Tuning' started by ToyotaNovice, Oct 8, 2009.
  1. Oct 8, 2009 at 9:22 AM
    ToyotaNovice
    ToyotaNovice [OP] Active Member
    Rocky
    Utah
    13 Tacoma Double Cab
    Okay I got a problem. When I drive up a hill, or really step on the gas I hear this rattling sound in the engine. :mad: It really only happens when my engine is sort of bogged down from either the hill or me stepping on the gas. When my engine catches up the sound goes away.
    I took it to a mechanic, he drove it, heard it, and says he doesn't know what sound it is but there's nothing wrong with my truck. My last Taco did it too. Has anybody had this problem before?
    Wish I could do a sound clip, but it only happens when I drive it and put some pressure on the engine.
    Please help! :confused:
  2. Oct 8, 2009 at 9:24 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    3.4L?
    I would look for a loose shroud on the exhaust.
  3. Oct 8, 2009 at 9:35 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is it a rattling sound or an engine PING?
    My 3.4L used to ping going uphills under torque (gas).
    If you think the engine is pinging - try a different (higher) octane gas.
  4. Oct 8, 2009 at 9:43 AM
    jab08
    jab08 Well-Known Member
    Alabama
    02 T4R 4wd
    Mine does the same thing going up a hill you hear a slight rattling noise. I have the 3rz which is the 2.7l. My only guess which is prob. no where even close because I AM NO MECHANIC by no means whatsoever, is maybe the valves rattling. But like I said I have no idea and would like to know exactly what it is also.
  5. Oct 8, 2009 at 9:49 AM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    yes this exactly what i'm thinking.higher octane and maybe a different brand.
  6. Oct 8, 2009 at 10:58 AM
    ToyotaNovice
    Rocky
    Utah
    It really sounds more like a rattling in the engine. I actually already put premium gas in it because it has the supercharger and I've done that since I've owned it (which is just only about a month). Maybe I'll buy some sort of fuel additive and see if that helps, but I'm thinking it's something different.
    Either way it drives me CRAZY! I mean, you want to show off your truck but when it's under torque it's got that spuddering rattle sound, insane! I want to fix it!
    I'll check out what was suggested and see if it helps.
    Any other ideas guys?
  7. Oct 8, 2009 at 11:01 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Don't worry about the fuel additives, just a waste of $. The premium will be fine and it is what you should be running.
    When was the last time the SC was serviced?
  8. Oct 8, 2009 at 11:11 AM
    Janster
    Jandy
    Lancaster, PA
    That was my next thought..... check the SC and make sure everything is still tight - and whatever maintenance it would need.
  9. Oct 8, 2009 at 11:14 AM
    ToyotaNovice
    Rocky
    Utah
    I don't know because I just bought the truck and I didn't ask when and if he had done it recently.
    I'll have to check that out, maybe take to get serviced at the dealership. Great idea!
  10. Oct 8, 2009 at 11:15 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    I had a 3.0 Ford engine that used to do that in hot weather. Using 89 octane solved the problem. It can't hurt to give it a shot.
  11. Oct 8, 2009 at 11:18 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I believe there are two generations of SC for the first gens. The first gen SC had bearing issues IIRC.
  12. Oct 8, 2009 at 1:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yeah, but that was figured out by 2000. Im thinking is pre ignition.
    OP, if the noise is happening when below 2500 rpm, choose a lower gear. Also..Check the plugs. If the plugs are due for replacement, use an Iridium plug 2 heat ranges cooler than OEM. Im kinda thinking the OEM plugs may have been installed when serviced.
  13. Oct 8, 2009 at 3:43 PM
    ToyotaNovice
    Rocky
    Utah
    Awesome! Thanks! I'll check this stuff out this weekend.
    Thanks!
    I'm also going to see if I can find out when and if the S/C has been serviced and who will do that.
    Thanks for the ideas guys!
  14. Oct 8, 2009 at 3:55 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  15. Oct 8, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How many miles are on it now??
  16. Oct 9, 2009 at 8:02 AM
    ToyotaNovice
    Rocky
    Utah
    My truck only has 44,000 miles on it.
  17. Oct 9, 2009 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The SC shouldnt need a rebuild until 100K miles....Check to make sure you have the correct pugs....in fact, just change them....At 44K, if they werent changed at 30K, they deffinatly need it.
  18. Oct 9, 2009 at 8:35 AM
    ToyotaNovice
    Rocky
    Utah
    Right on! I don't know if they were done at 30k cause I didn't own the truck at that time....so.....better safe than sorry and just I'll set up an appointment to have the Iridium plugs put in and see what that does! Thanks!!
  19. Oct 12, 2009 at 7:07 AM
    ToyotaNovice
    Rocky
    Utah
    So far....
    I have replaced my stock air filter with the afe pro dry and I haven't heard the rattle except for once. (in fact I only barely heard it once when I really gave it some torque going up a hill - but NOTHING like it was before!!) :D
    So...whatever that did it seemed to work. I'm still planning on replacing the plugs this week or early next week. I figure it can only help and might fix it completely. I'll keep you updated.
    Thanks for the suggestions!!!
  20. Oct 12, 2009 at 7:29 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
