Rattling noise during Acceleration
Discussion in 'Technical Chat' started by JappyFish, Jun 2, 2015.
  1. Jun 2, 2015 at 7:27 AM
    JappyFish
    JappyFish [OP] New Member
    Just joined the forum and probably should have joined earlier.
    I've got a 2013 TRD Tacoma 4WD Double cab and have been recently been hearing excessive rattling noise when I accelerate. After a little bit of research I've narrowed it down to either the heat shield rattling or the rear portion of the drive shaft. It definitely sounds like it is coming from the front though.
    Is this a dangerous issue? I am heading to Florida tomorrow from South Carolina and I don't have time to take my truck in to be looked at before tomorrow.
  2. Jul 10, 2015 at 6:41 PM
    Jmoreno
    Jmoreno New Member
    Sway
    Portland, Oregon
    Super White 2014 Tacoma Sport Long Bed
    I've been hearing the similar noise I feel. Doesn't make the noise when sitting and reving the engine but when acclerating it makes the moderate to loud, metal rattling noise around 1500 RPM predominantly. I hear it slightly when above 1500 RPM and faster speeds but more so at lower speeds in 2nd or 3rd gear. I have an automatic 2014 Tacoma Sport Dual Cab.
    I also feel it struggle to shift properly when coasting down hills. I feels as if it gets stuck around 3000+ RPM and won't shift until I give it more gas. Does this happen to you? I'm taking it in tomorrow and hopefully will out with some resolution and answers.
  3. Jul 10, 2015 at 6:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm gonna guess heat shields but lubing the u-joints wouldn't hurt.
  4. Jul 10, 2015 at 7:50 PM
    Jmoreno
    Jmoreno New Member
    Sway
    Portland, Oregon
    Do you think this has to do with the shifting issue?
  5. Jul 10, 2015 at 7:59 PM
    mtntacoVA
    mtntacoVA Member
    13 Taco, 24 4Runner
