rattling noise while acclerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco08, Mar 6, 2008.
  1. Mar 6, 2008 at 12:34 PM
    taco08
    taco08 [OP] Member
    hey guys, first post here.
    i got a new 2008 tacoma about 2 weeks ago. a few days after i bought it i have noticed a rattling noise while accelerating. it really seems to start rattling around 2000-3000 rpms. it doesn't make the noise when i'm coasting, braking, or when revving the engine in park. it isn't terribly loud but it is annoying and can be heard over the radio. could it be the fuel? i've been putting regular 87 octane in it since i've gotten it, not premium, which now that i think about it is what toyota recommends.
    i hope that's what it is...i'd hate to already have something wrong with it and since i've had great past experiences with toyota. thanks
  2. Mar 6, 2008 at 12:55 PM
    corywilson13
    corywilson13 Canadian Taco
    Vancouver Island, British Columbia
    08 Taco sr5 Access 6spd Std
    Grom-Ipod, Bed Mat, Tool Box with TRD mat, Inifnity 6x9's.
    i had a rattle and all it was was a heat shield that had bent up and was touching the driveshaft
  3. Mar 6, 2008 at 12:55 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    You could give us a little more info....
    Such as which transmission, engine, 4x4 or 4x2....
  4. Mar 6, 2008 at 12:58 PM
    taco08
    taco08 [OP] Member
    4x2, v6, auto
    i suspected the fuel because when i drove it around before my first fill up i never noticed the noise. i've only noticed it after i've filled up the tank a couple of times.
  5. Mar 6, 2008 at 1:01 PM
    Khaos
    Khaos Big Member
    Bryant
    Is it knocking or rattling?
    If its knocking, try running higher grade gas.
  6. Mar 6, 2008 at 1:03 PM
    taco08
    taco08 [OP] Member
    what's the difference? the best way that i can describe it is like a rattling noise that only comes on while accelerating. i'll definitely running higher grade gas next time.
  7. Mar 6, 2008 at 1:35 PM
    ERdept
    ERdept Well-Known Member
    Now is it rattling or ticking?
    I have another thread on ticking, which is apparently common, but benign.
  8. Mar 6, 2008 at 1:39 PM
    taco08
    taco08 [OP] Member
    i would say it's much more similar to a rattling noise.
    i can't figure out why the noise is virtually nonexistent or very slight when revving the engine in park but when you're accelerating, particularly around 40-50 mph, it becomes more obvious. it seems to go away again when you get at 60+ and at interstate speeds it isn't even there.
    da hui i don't think it's knocking.
  9. Mar 6, 2008 at 4:15 PM
    Dutch
    Dutch Well-Known Member
    Wilmington, NC
    07 4x4 Taco
    This is my guess as well. The heat sheild may be vibrating against something.
  10. Mar 7, 2008 at 1:40 PM
    taco08
    taco08 [OP] Member
    upon further examination, it probably does sound more like a "ticking" noise rather than a "rattling" or "knocking" noise. also, the sound does come up when revving the engine in park.
    does anyone have any further information on the ticking noise that is apparently common? any idea on what's causing it and what gets rid of it?
  11. Mar 7, 2008 at 2:44 PM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    are you sure that the ticking noise isn't just your fuel injectors firing? i noticed mine were a little more audible after install my volant ram air and CAI setup
  12. Mar 7, 2008 at 2:55 PM
    taco08
    taco08 [OP] Member
    i wouldn't know even if that is the case. i've never heard the fuel injectors firing on any other car i've been in or driven and i haven't put any mods on this truck. i've only had it about 2 weeks.
  13. Mar 7, 2008 at 2:56 PM
    taco08
    taco08 [OP] Member
    i wouldn't know even if that is the case. i've never heard this noise on any other car i've been in or driven and i haven't put any mods on this truck. i've only had it about 2 weeks. it's not particularly loud but it is annoying. i didn't notice the noise when i first picked up the truck from the dealer and only began to notice it a few days after i bought the truck and after i had refueled, which made me think it's the low octane gas i've been putting in it.
  14. Mar 7, 2008 at 3:11 PM
    Zebra
    Millington, TN
  15. Mar 7, 2008 at 3:17 PM
    Zebra
    Millington, TN
    also do a youtube search for "engine knock and pinging" to if it sounds similar to what you are hearing
  16. Mar 7, 2008 at 3:18 PM
    taco08
    taco08 [OP] Member
    thanks for finding this zebra. what this article talks about sounds like what i've got...the pinging/ticking/whatever you want to call it noise occurs really only at higher rpms and while accelerating. the noise is virtually nonexistent at cruising speeds. hopefully it's just the lower grade fuel i've been using. i'll obviously finish out this tank first then fill up with the 93 octane next time.
  17. Mar 7, 2008 at 3:22 PM
    taco08
    taco08 [OP] Member
    yeah i already did that. that's part of what led me to believe it's not an actual knocking. that knocking noise in those videos is much, much more pronounced and obvious and occurs when the engine is idling. my engine sounds perfectly normal while idling and the noise i've got is more subtle.
    BTW do you use premium in your tacoma?
  18. Mar 7, 2008 at 3:32 PM
    Zebra
    Millington, TN
    i run shell 87 octane in my tacoma. no problems. i learned about some of those "value" gas at some stations in my last car
    i have the bottom of barrel tacoma. the only factory option i have on my 08 4x2 regular cab base model is air conditioning. i'm adding what i want to the truck little by little. that way i can get what i want without having to pay for shit i don't need and plus its more fun to mod!!!!
  19. Mar 8, 2008 at 8:00 AM
    waynea4
    waynea4 Active Member
    Western N.C.
    Red 08' Double Cab TRD Sport 4X4
    I would try another gas station or a higher grade of fuel, it sounds like you have a spark knock. If the fuel you are buying is not up to par the engine will make a pecking noise because it is not getting the right amount of fuel or octane. This is really common on supercharged vehicles and even on vehicles with a "performance chip". I had a dodge with a performance chip installed and when I used low octane fuel it would spark knock just like you are describing. If changing fuel brands or octane levels does not work take that sucker to the dealer. Also have you made sure the oil level in the engine is correct, might want to check that as well. Good luck!
