Rattling noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by 9RDaz, Nov 9, 2017.
  1. Nov 9, 2017 at 8:48 AM
    9RDaz
    9RDaz [OP] New Member
    04 TRD off road
    3" ultimate lift toytec. 285/75/16 BF Goodrich AT
    Anybody know what this noise might be?? It only happens when I take my foot off the gas and when its cold out. I've had my timing belt and water pump changed and its still making that noise. If I accelerate, the noise goes away. I tried to post a short vid but site says something extension.
  2. Nov 9, 2017 at 8:51 AM
    Ojbarrón
    Ojbarrón Member
    04 tacoma v6
    I have an 04 doing the same thing. But if i go under 20 it goes away. I have no idea driving me crazy
  3. Nov 9, 2017 at 9:07 AM
    9RDaz
    04 TRD off road
    Won't do it when it idles so I don't know where its coming from. Prob front motor but its getting worse. I tried to upload a short video but it won't allow me. If I accelerate. It goes away
  4. Nov 9, 2017 at 9:13 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    You can manually turn the throttle while under the hood to rev the engine, or have someone else rev it, then look for the source. I guess even with electronic throttle you can still do this.
  5. Nov 9, 2017 at 9:17 AM
    9RDaz
    04 TRD off road
    I tried that.. The truck has to be moving. I wish I could post the noise
  6. Nov 9, 2017 at 9:19 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Upload the video to youtube then post the link here.
  7. Nov 9, 2017 at 9:32 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Without hearing it I am going to guess your center support bearing (also sometimes called the carrier bearing) that goes in the middle of the two pieces of driveshaft.
    When I first got my 2000 PreRunner 2.7 with 150K miles on it, it made a noise upon deceleration that was similar to a screeching drive belt. No noise on acceleration. A review of the service records of the prior owner revealed a repeat complaint to Pep Boys of belt noise after water pump replacement and they repeatedly adjusted the drive belts. Turned out to be a bad bearing and a fairly cheap and easy fix.
