rattling noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awwmann, Apr 5, 2010.
  1. Apr 5, 2010 at 1:59 PM
    awwmann
    awwmann [OP] Well-Known Member
    pat
    staten island new york/ redbank nj
    2015 4x4 double cab trd sport
    bilstein 5100/ 265/70/17
    I have a rattle noise every time i hit a bump coming from front end . i made sure everything was tight this morning couldnt find anything . if i touch the brake pedal while going over a bump rattle goes away any ideas what it could be ?
  2. Apr 5, 2010 at 2:18 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Brake pedal? hmmm I would start with the easy stuff, wheel nut torque, loose pins / bolts on the caliper.
  3. May 6, 2010 at 4:11 AM
    CCRT
    CCRT Member
    2008 Tacoma Access Cab 4X4 Indigo Ink
    I'm having the exact same issue. Rattle goes away when slight brake pressure is applied.
