Rattling/Screeching/EffingAnnoying
Discussion in '1st Gen. Tacomas (1995-2004)' started by Surf5rgurl, Jan 12, 2016.
  1. Jan 12, 2016 at 10:29 PM
    Surf5rgurl
    Surf5rgurl [OP] New Member
    99' Pre Runner. Alright this noise it's making is driving me crazy. It sounds like a screeching or rattling and This only happens when I'm rolling above 35mph. It stops when I accelerate and gets quiet when I break. Maybe not so much a screech but a rattle or something that needs lube. Idk Please help.
    -Surf5rgurl
  2. Jan 13, 2016 at 9:58 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    did you lube the drive-shaft zerks? any chance to record the noise?
  3. Jan 13, 2016 at 2:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you are an extracab or a double cab, check the center support bearing in the rear driveshaft for excessive play since you will be under there anyway greasing all the ujoints on the driveshafts.
    When the carrier bearing begins to fail, they can get noisy.
  4. Jan 13, 2016 at 3:29 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    can you pinpoint the location?
